May 20, 2021, 04:14 |
Pump Performance Curve
Yosri Abdallah
Rep Power: 4 |
Urgent ! need help I'm working on a centrifugal pump, the goal is to evaluate the performance curve of the pump (i.e head vs flow rate) now, i started by using a Total pressure inlet (0 atm) and a mass flow outlet and by changing the desired outflow i would just simply calculate the delta p based on that flow rate and deduce the elevation ..however, i was told that i need to do the opposite thing, meaning that i have to impose a head value and then evaluate the out flow as a result . the problem is I can't find a way to impose that condition, let's say that i need to find out the flow rate of the pump at a total head = 30 m ..how can use that 30 m to determine the pressure needed at the outlet since i have no information about the flow velocity any suggestions please ?? Thank you |
May 20, 2021, 14:44 |
Lucky
Rep Power: 66 |
You can do it either way, you get a fan curve regardless.
If you can convert deltaP into a head you can go backwards and convert a 30 m head back into deltaP no? Where are you stuck? A velocity isn't needed to go from elevation head to pressure head. |
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points | Simurgh | OpenFOAM Meshing & Mesh Conversion | 4 | August 25, 2023 07:58 |
gmshToFoam error | erkampasha | Main CFD Forum | 1 | March 22, 2021 13:52 |
OpenFOAM error | Vinay Kumar V | Main CFD Forum | 0 | February 20, 2020 09:17 |
Pump characteristic / performance curve | husker | STAR-CCM+ | 4 | February 20, 2012 03:46 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
