December 7, 2014, 23:42 |
Axial Fan-CFD Vs.Test
tamil nadu
Rep Power: 11 |
From CFD simulation of 294 frame axial flow fan, i got fan performance as 22.95% at P=100.3 Pa,Q=582 m3/hr,2863 RPM.But the same fan during the air flow test provides fan efficiency as 42.20% at P=100.72 Pa,Q=1157 m3/hr,2879 RPM.Both operating points are same, but cfd predict around 50% less flow rate than test. What would have gone wrong in the simulation? kindly seek your help to address this issue. For your reference CFD Setup info: 1. Physics: In compressibility flow 2. Analysis type: transient 3. Approach: Frozen rotor 4. Convergence ratio: 0.0001 5. Turbulence Model: K- epsilon 6. Fan and chamber considered(Shroud ignored) 7. Boundary layer: Single layer used Test info: 1.Air flow test chamber-According to ANSI/AMCA 210-07 2.Fan-Shroud and Chamber used in test ( Shroud ignored in CFD we have got good correlation between test and CFD other frames of fan(350 mm,370 mm) but in this frame 294 mm i am getting unreasonable correlation of 50% in CFD.) Thus, I could see my CFD simulation has failed to capture large flow generated by fan in the test. How to capture resonable flow prediction in CFD simulation. I used AutodeskCFD2012 for this simulation. Regards Anand madeshwaran |
December 10, 2014, 03:34 |
Rep Power: 13 |
Hey,
Do you have shroud in your tests and not in your CFD simulations? If so, you can't expect the same results. Tip clearance has a huge effect on the fan performance. You should work on the cells in the boundary layer, one layer is insufficient even if you use SWF. Have you checked y+ value at the end of your simulation? I suspect you are using an automatized software for simulation. You can also, try using more advanced software in case you have appropriate background in CFD. Hope you'll solve it soon. Cheers, Koray |
December 10, 2014, 04:40 |
tamil nadu
Rep Power: 11 |
Mr.Koray,
Thanks for your comments. Yes, Like you. i also suspect the shroud.At present, i am trying to include shroud in my CFD setup.I used autodeskCFD for this simulation.But my big doubt is how could i can get good correlations for other fans(305,350, and 370 fans) without including shroud in the CFD simulation? What will be the recommenced Y+ and boundary layers settings for axial fans(car radiator application). For this case, Will you recommend CFX with ICEM CFD or AutodeskCFD ? |
December 10, 2014, 09:32 |
#4 | |
Rep Power: 13 |
I use ICEM CFD for mesh generation because it has a large range of functionality. With enough experience in it, you can do pretty much anything. |
December 10, 2014, 22:08 |
tamil nadu
Rep Power: 11 |
Thanks Mr.Jpando. Your hint at boundary layer and ICEM CFD will help me a lot.
Regards Anand |
December 15, 2014, 15:00 |
#6 | |
Rep Power: 13 |
You should always take shroud into account, it's essential in this problem. Autodesk CFD is the new CF Design. As far as I know, you can't have much freedom and flexibility in creating mesh in Autodesk CFD while you have full control in ICEM CFD. When it comes to turbulence modelling and basic algorithms that these two software use, it's not much different. But still, CFX, has some advanced tools just for turbomachinery industry. If you have the chance to use CFX&ICEM CFD and enough time to learn them then, pick them. Cheers, Koray |
Axial Fan Simulation - physics laws not held true | Giovan | CFX | 18 | August 2, 2020 14:44 |
Axial Fan-CFD Vs.Test | Anandltvs | Autodesk Simulation CFD | 1 | December 17, 2014 09:32 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
public CFD Code development | Heinz Wilkening | Main CFD Forum | 38 | March 5, 1999 11:44 |
