muultiple inlets how to initialize
Like Tree1Likes
  • 1 Post By hwet
Old   February 7, 2016, 04:34
Default muultiple inlets how to initialize
sandy
saddy is on a distinguished road
friends ...
my problem is described as follows
1. rectangular channel, hole at the bottom surface.
2.[ inlet face, hole] both are VELOCITY INLETS.
3. AIR through face inlet, WATER through hole
4 how do i specify volume fraction for both inlets while INITIALIZING
saddy is offline   Reply With Quote
Old   February 12, 2016, 01:41
hwet is on a distinguished road
through patching
hwet is offline   Reply With Quote
Old   February 13, 2016, 14:04
sandy
please care to elaborate, if you might???
Old   February 14, 2016, 01:40
you can mark, face, regions, volumes etc through adapt->mark.
dont actually adapt the mesh but just mark the region out.
next go to initialize->patching
select the phase you want to patch, you can patch velocities, volume fractions etc, for the secondary phase you will be able to patch the volume fraction i.e. 1, in the region where there is only water.
plot the contours of the volume fraction to see if the patching actually worked. you will be able to see water at the face/surface/region you patched in the contours before actually starting the simulation
post back if it worked.
goodluck
saddy likes this.
Old   February 18, 2016, 16:09
sandy
Thanks buddyy
why the inlet velocity magnitude differrent from the value i initialize? eyuhock FLUENT 26 April 20, 2015 21:34
Mixture of the same fluid from 2 inlets godon Fluent UDF and Scheme Programming 0 October 15, 2012 08:04
Two pressure inlets problem Medison CFX 1 August 22, 2012 06:50
Multiple Inlets Charlie V FLUENT 0 May 28, 2001 02:29
create Volume with inlets Roman Bohnes FLUENT 10 December 6, 1999 04:43
