How to handle the list in an openmp parallelism
Old   January 25, 2008, 17:30
Default How to handle the list in an openmp parallelism
gonski
I met across a big problem in parallelizing my code. In my code, it needs to create a list to consider interactions between particles, see the following pseudo code. To parallelize the part of code, How can I avoid race conditions for k, f1,f2 in multi-thread calculations in the parallel loop?
Cheers, Gonski
Pseudo code to create neighbor list for particles
k=1
do i=1, n
Note: here many lines have been snipped
f1(k)=c1
if(something )then
f2(k)=c2
endif
if(something)then
k=k+1
endif
enddo
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
