February 15, 2008, 14:57 |
Error in Fluent ?
Dear all
I am simulating flow in a turbine rotor. when I am using the specific heat value typical of STP conditions, I am getting correct values of turbine performance (efficiency) in turbo report panel. but as i change the value to any other value i get the resutls with 12-15% deviation. Is there any error in Fluent. Can any body suggest me that how the fluent calculate the efficiency for constant and variable gas properties. Thanks |
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 04:16 |
A Problem of Fluent Interpreted UDF: parse error | knight | Fluent UDF and Scheme Programming | 25 | August 16, 2018 10:26 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
Compared MRFSimpleFoam and Fluent in a centrifugal pump! | renyun0511 | OpenFOAM Running, Solving & CFD | 8 | July 6, 2010 06:24 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 16:48 |
