Open source codes for VOF simulations
Old   February 27, 2008, 06:50
Default Open source codes for VOF simulations
Asghari
Hi all.
Does anyone access to a free open-source code(not conventional commercial softwares such as FLUENT ,Starcd,...) simulaing VOF (volume of fluid) simulation ?
If you access to it, can I appeal you to send it for me?
What's geometry for it ?
It is preferable for me that code has been written by a program language such as (FORTRAN,Visual C, BASIC, MATHLAB,..).My email address is mehdiasgh@gmail.com
Thanks a lot for any help.
I need to this
Old   February 27, 2008, 13:51
Default Re: Open source codes for VOF simulations
andy20
Try OpenFoam. You can look it up on the cfd-online website, and visit the OpenFOAM site and discussion forums at:
http://www.opencfd.co.uk/openfoam/
It can do dam-break type problems, as shown by the graphics on the page:
http://www.opencfd.co.uk/index.html
It runs best on Linux/Unix.
I have had no problems with OpenFOAM itself. However finding a suitable open-source 3-D meshing tool that can handle boundary layers for CFD calculations, etc has been very difficult.
Good luck, Andy
Old   February 28, 2008, 04:22
A.K.
Hi, Andy! Have you really had no problems with OpenFOAM? I have heard that users face convergence problems with this solver. In particular, they need very small Courant number to get the convergence. This topic was under discussion in the OpenFOAM forum.
Old   February 29, 2008, 04:25
andy20
A.K,
Sorry - I should have qualified my statement somewhat...
I haven't had any convergence problems with OpenFOAM on the problems I've used it for, which have been slow viscous flow in complex geometries.
I haven't been able to generate a mesh with suitable prisms at the boundary for the high speed gas flow problems I'm interested in. Therefore I haven't tried OpenFOAM for these more difficult cases, as I wouldn't trust results from any FVM code with any pure tetra grid in these geometries...
So I can't really advise on experience with convergence problems. Nevertheless, IMHO OpenFOAM does appear to be one of the most active and complete open source CFD suites around at the moment, supports the free surface flows the OP asked about, and there seems to be a lot of support available on the discussion forums. So I mantain it's worth a look for the OP...
Best regards, Andy
Old   February 29, 2008, 17:10
alpha
Hi Andy
Its really difficult to generate complex geometries and meshes with blockMesh utility that OpenFOAM uses. Which software do you use? Are you aware of any open source software that could generate unstructured mesh and is compatible with OpenFOAM.
Thanks Alpha
Old   March 2, 2008, 08:38
andy20
Alpha,
I agree - it seems very hard to find a good mesh generation tool for OpenFOAM. As I said in my last post, that is what has stopped me using it more often.
Netgen is often mentioned on the OpenFOAM forum. I think it is mainly a finite element tool though, as it only seems to generate fully tetrahedral meshes with no boundary layer / inflation meshing options. Therefore Netgen meshes are not really suitable for CFD. It is easy to use (but hard to compile - I suggest using a binary installation if possible).
GMesh also gets mentioned, but I've not yet used that successfully - and I don't yet know if it supports boundary layer meshes.
I hope that anyone else reading this thread will mention any good tools that they know of - because I think we would both like to learn about them!
Good luck, Andy
Old   March 2, 2008, 20:12
alpha
Hi Andy
Unfortunately both netgen and Gmsh generate structured mesh where as i often need to take into account formation of boundary layer in my problems. I have recently started using OpenFOAM and found it very good tool for CFD analysis. Only problem that i am facing is generation of complex geometry and mesh. Thanks for your answer.
alpha
Old   March 27, 2008, 18:18
Gert-Jan
GID?
Old   March 28, 2008, 07:28
alpha
Sorry what is GID? Thanks
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 17:33
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 02:36
