alternatives to moving mesh
Old   March 31, 2015, 22:15
Default alternatives to moving mesh
Thangam Natarajan
Thangam is on a distinguished road
If one has to simulate oscillating plate/solid wall ( sinusoidal function of time) in a domain (a simple piston movement in 'y' direction), the obvious way would be scenario 1. For brevity, assume there is no topological changes involved.
Scenario 1:
To use dynamic mesh and move the mesh points via the prescribed equation.
Scenario 2:
The fluid near wall takes up a zero velocity (assuming no slip). Now, With this in mind, using an oscillating velocity boundary condition in 'U' at the plate/solid wall (working out the velocity of the fluid for the plate's displacement amplitude) as the fluid should obey the no slip condition and produce the flow features similar to a moving mesh ?
Will the result of scenario 2 be different to scenario 1? Is scenario 2 the right way to represent a near wall fluid with no slip? what happens to 'k' and 'pressure' in scenario 2?
Thanks
Thangam.
Thangam is offline   Reply With Quote
dynamic mesh, moving mesh., no-slip, wall boundary condition
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
How to let the mesh motion solver just solve a small region near a moving boundary? zhajingjing OpenFOAM Running, Solving & CFD 9 April 28, 2016 04:15
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
