LES: fully developed flow at the inlet of a duct
Old   June 12, 2008, 13:59
Default LES: fully developed flow at the inlet of a duct
cfd novice
Hi guys
I wanna impose fully developed flow at the inlet of a duct. I do not have much time so what will be best option to do that. All kind of ideas are welcome. Thanks in advance for your help.
cfd novice
Old   June 13, 2008, 11:24
Default Re: LES: fully developed flow at the inlet of a du
agg
If you look up Frank White's Fluid mechanics you will get solution for fully developed laminar flow in a duct. You can then impose fluctuations on it if you want turbulent flow at inlet.
Old   June 13, 2008, 11:48
cfd novice
Hi agg
Thats exactly what I was looking for. How do I impose fluctuations at the inlet? There is no such facility in CFX to do that. Thanks
cfd novice
Old   June 13, 2008, 17:39
agg
Is it possible to read in inlet profiles every few time steps in CFX? If so, you could have a set of files that you create with the fluctuations superimposed on the mean laminar profile and have CFX read it.
Old   June 14, 2008, 06:50
cfd.novice
But that would only give me interior fluctuations, I was trying to obtain fluctuations at the inlet boundary. Thank you for your answer.
cfd.novice
Nusselt numbers for fully developed laminar flow Danro Siemens 8 July 19, 2012 07:22
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
translational periodic BC vs Fully Developed Profile at Inlet Prakash.Paudel FLUENT 1 August 20, 2010 11:01
what is the fully developed fluid flow? charles CFX 7 November 13, 2006 09:48
fully developed flow in diffusor Fabian CFX 1 September 19, 2001 18:13
