Why do oscilations appear when reducing the time step? |
May 29, 2015, 16:20 |
#21 |
Filippo Maria Denaro
Rep Power: 71 |
May 30, 2015, 03:23 |
#22 |
Hector Redal
Rep Power: 16 |
For stability condition I take into account two terms: One term for the convective stability condtion (which should be less than h/u) and another term for the diffusive stability condition (which should be less than h^2/(2 nu), being nu the kinematic viscosity)
May 30, 2015, 03:27 |
#23 | |
Rep Power: 71 |
actually, both terms act simultaneously giving a CFL(Re_h) stability region. It can happens that at low Re_h you cannot take dt/h constant but you have to reduce further the time-step. Thus, I think you have first to check if oscillations still appear when you solve, but on the same grid of value h, with the two time steps |
May 31, 2015, 04:20 |
#24 |
Hector Redal
Rep Power: 16 |
I have already checked this point: us9ing the same grid but varying the dt. When I use a coarse grid, and I reduce the dt, the small oscillations does not appear. This problem (small oscilations) only appear when using a fine grid and reducing the dt.
May 31, 2015, 04:26 |
#25 | |
Rep Power: 71 |
that probabily means you are approaching the limit of the stability region and on that fine grid (small Re_h) you need a smaller cfl (smaller dt). |
June 6, 2015, 05:00 |
#26 |
Hector Redal
Rep Power: 16 |
I have reduced the threshold of the iterative solver, along with the time step, and the problem has been eliminated. There is not any oscilation in the solution as the time step is reduced.
Thanks you all for your kind support and help. |
June 6, 2015, 05:47 |
#27 | |
Rep Power: 71 |
yes, at small dt you need to improve the convergence threshold otherwise we get often small oscillation from a time step to an other |
oscilations |
negative min.(alpha1) value interFoam | Arjun Jayakumar | OpenFOAM | 11 | December 21, 2019 10:59 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Rapidly decreasing deltaT for interDyMFoam | chrisb2244 | OpenFOAM Running, Solving & CFD | 3 | July 1, 2014 16:40 |
InterFoam negative alpha | karasa03 | OpenFOAM | 7 | December 12, 2013 03:41 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 04:35 |
