May 31, 2015, 15:15 |
Water Fountain Shape
Bill Rienstra
Can anyone explain the physics behind the shape of the attached water fountain envelope? If the water droplets were just ballistic, I would expect a hyperbolic shape but this envelope curves back in.DS3_5106A.JPG
May 31, 2015, 17:38 |
Perhaps the reason for that is moving air: water moves air due to non-slip on water surface, and there should be a kind of voricial air motion inside the fontain (ring vortex).
The second possibility is the surface tension which tends to reduce fontain surface area Last edited by truffaldino; May 31, 2015 at 18:39. |
June 1, 2015, 08:12 |
Alex
Rep Power: 46 |
Great, fluid dynamics in real life . I would opt for surface tension.
The surface tension acts in a way trying to reduce the surface area of the interface, which results in the water fountain tightening up towards the bottom. You could check this hypothesis by widening the gap where water is ejected from the fountain. This increases the inertial forces compared to surface tension effects and the fountain should get a more parabolic shape as you expected. |
June 1, 2015, 08:18 |
Filippo Maria Denaro
Rep Power: 71 |
I also think about surface tension...additionally, I see the jet opening in a real laminar way, it is projected to avoid developing turbulence
Mass imbalance problem in multiphase water and steam CFX case | Antech | CFX | 1 | October 26, 2020 04:03 |
To make water shape more smooth | flow_3d_user | FLOW-3D | 1 | August 12, 2015 06:48 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
