June 4, 2015, 12:57 |
Having problem in Tecplot 360, movie
Mike
Rep Power: 15 |
I have been using Tecplot 10 for a long time and was quite satisfied with it but unfortunately have to move to 360. For making animation in tecplot 10, I could easily load a number of snapshot and then: tools-->animate-->zones and that's it. But I can not do the same thing with Tecplot 360. I'd appreciate your help. |
June 4, 2015, 13:05 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
Are you sure? I used 360 some times ago to make animation and it worked.... But I loaded multiple files to make the animation |
June 4, 2015, 13:23 |
Mike
Rep Power: 15 |
I did the same thing. I loaded several files (basically different moments from the same flow field), but I do not find the option for making animation.
I do the same thing on my old computer which has Tecplot 10 and it works very simple as I said. Probably they put that option some where else but I do not know where that is? is that possible for you to tell me what steps I should take to make the animation after I load the files? |
June 4, 2015, 13:36 |
Rep Power: 71 |
As in the older version, I have several zones and going to animate I can see the sequence of zones......
June 4, 2015, 13:48 |
Mike
Rep Power: 15 |
but I can not see. it is not activated in my 360.
Maybe because they are all named zone 1 (although the name of files are 1,2,3,...) they are all recognized zone 1 in Tecplot. In Tecplot 10, it was not a problem and the header of all files were the same. It automatically recognizes it. What header do you use? |
June 4, 2015, 14:04 |
Mike
Rep Power: 15 |
Actually, I got that.
I have to add strandid=... solutiontime=... in the header. |
June 4, 2015, 14:13 |
Rep Power: 71 |
yes, you have Tecplot to recognize as different zones
Tecplot 360 2011 R2 preview with OpenFOAM data loader available for evaluation | scott_rumage | OpenFOAM Post-Processing | 50 | January 23, 2017 02:49 |
Problem in Importing CFX results in Tecplot 360-2012 | safikhani_hamed | CFX | 7 | October 12, 2013 06:29 |
making movie under tecplot with dat files | jjchristophe | FLUENT | 3 | July 11, 2013 09:20 |
How to plot Lift and Drag Coefficients using tecplot 360 | RuiVO | Tecplot | 5 | April 13, 2012 14:17 |
A tecplot problem | scubme | FLUENT | 2 | November 22, 2004 04:43 |
