June 8, 2015, 19:07 |
2d turbulent flow parallel plates matlab
Rep Power: 12 |
I am currently trying to determine the turbulent velocity profile with matlab for a flow between two parallel plates. In order to do so, I am using the universal velocity profiles of Karman and Taylor/Prandtl. The veloityprofile is considered to be symmetric. In both cases the velocity gradients close to the walls show realistic behaviour. Still I have my doubts concerning the values on the centerline where the velocity profile shows a peak. Does anyone know models which represent a smoother transition on the centerline or rather a better approximation for high y+ numbers? A plot of the velocity profile and the corresponding Matlabcode can be found in the appendix. Every input is welcome Greetings P_P |
June 9, 2015, 03:57 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
Hello, I suggest plotting the velocity u+ versus y+ so that you can better check for viscous sub-layer and log region |
June 9, 2015, 07:00 |
#4 | |
Rep Power: 71 |
to check further, you can superimpose the law u+=y+ and the log law using a logarithmic scale |
June 9, 2015, 09:42 |
Rep Power: 12 |
I don't know if I unterstood you well. I have created a semilogarithmic plot u+ versus y+. What is the idea behind checking the laminar sublayer for my problem?
June 9, 2015, 11:30 |
Alex
Rep Power: 46 |
Looks reasonable.
The "peak" in your initial figure is due to the fact that the equations you used are for the flow over a flat plate with an infinite fluid domain. Not for a fluid between parallel plates. |
June 9, 2015, 12:11 |
Rep Power: 12 |
Hello flotus1,
thanks for your reply. Do you know any models which offer a better desciription of the velocity profile between two parallel plates? Or is it unevitable to excute a CFD simulation with common CFD software in order to export the velocity profile. P_P |
June 9, 2015, 14:28 |
Alex
Rep Power: 46 |
I havent come across any analytical formula for this case.
However there is plenty of DNS data available for turbulent flow between 2 parallel flat plates. Here is just one example... |
log law, matlab, turbulent flow |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 07:08 |
Nusselt Number for flow between flat parallel plates | vijud25 | FLUENT | 2 | November 23, 2015 12:29 |
turbulent or laminar flow | student2008 | Main CFD Forum | 5 | August 24, 2013 05:33 |
Turbulent Flow in Straight Square Duct - k-ep Validation | mcclud | STAR-CCM+ | 2 | August 7, 2012 16:56 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
