Loss of Conservation of mass on a Pressure Corection DNS Solver
Old   November 9, 2010, 09:16
Default Loss of Conservation of mass on a Pressure Corection DNS Solver
Dan
dandalf is on a distinguished road
Hi I have written a DNS solver for incomressible flow, bassend on a varying resolution cartisean grid.
I programmed it with an object oriented aproach around finite volume grid elements.
When I came to validating my code, I chose to use,
(Schafer et al; 1996) "Benchmark computations of laminar flow around a cylinder". Notes on numerical fluid mechanics 52, 547-566
The first test I chose was the 2D unit circle in a curved fluid velocity profile, and Re = 100
Which should have resuled in a nice von Karman shedding vortex wake,
As the Attached Picture Shows, the solver seems to be converging on a steady state solution, furthermore the flow visualisation clearly shows that local conservation of mass is failing.
The calcualted forces seem so be in the right ball park area, but show no signs of oscillation.
Could anyone sugest any reasons this could be happening,
Dandalf
dandalf is offline   Reply With Quote
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 05:37
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
DNS Mass conservation aslekay Main CFD Forum 0 November 17, 2009 20:47
Loss of mass Pascale Fonteijn CFX 8 April 23, 2003 15:59
