request to Tom--LES in Channel flow
Old   August 8, 2008, 18:28
Default request to Tom--LES in Channel flow
pankaj saha
First of all , thanks to agg and tom. My, Re is 205. And , my resolution near the wall is 0.68 wall unit. Still, according to agg, i will try, with Re=180.
How, could i understand , my intial condition is divergence free or not?
As, i am using a profile like below for i.c----
u(x,y,z)=(1-y^8)+10*(rand(iseed)-0.5) v(x,y,z)=0.0 w(x,y,z)=0.0
rand(iseed) will give value between 0,1.
So, my disturbence is -5,+5 at random values.
Could, you please, tell me , whethere, this field is satisfying continuity or not? ------------------------------------------------------
Tom, is my random disturbence fullfill the necessary large scale and amplitude.
tom, could you please, tell me what is the exact expression for i.c condition you , used.
Do, you give v=0.0, w=0.0 or anything else.
Could you please, send me the expression you used.
one more thing---how you specify the mean pressure gradient?
I have used dp/dx=1.0, beccause, my code is nondimesionalized by half channel height and friction velocity. am i correct?
or what else you are using?
Old   August 9, 2008, 05:38
Default Re: request to Tom--LES in Channel flow *NM*
neilashkumar
Old   August 11, 2008, 04:09
pankaj saha
hi,
you did not post anything.
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 21:25
Fluent LES Channel Flow santosh FLUENT 0 January 7, 2010 21:11
LES of channel with cylic boundary mapping boundary conditions Thomas Baumann Siemens 0 August 24, 2009 09:53
Turbulent channel flow by LES Paul Main CFD Forum 14 July 6, 2009 04:02
compressible channel flow.. R.D.Prabhu Main CFD Forum 0 July 17, 1998 17:23
