July 6, 2015, 01:26 |
Pressure below zero
Rep Power: 10 |
Hello everyone!
I'm suffering from cfd-programming all these days. when I simulating a blunt body with Roe's FDS schemeand some other schemes(Ma=5), the pressure at the wake region often becomes negative,but when there is no wake region, the simulation will be sucessful,how can I cope with the problem? Last edited by cfdfarmer; July 7, 2015 at 00:15. |
July 6, 2015, 13:11 |
Ashwani
Rep Power: 12 |
May be you need to use some sort of preconditioning. Is it laminar or turbulent flow?
July 6, 2015, 23:58 |
Rep Power: 10 |
July 7, 2015, 12:19 |
Ashwani
Rep Power: 12 |
Preconditioning will be little difficult to apply, anyhow reference is here . The reason I asked for laminar or turbulent, is on such high Mach number, your code may need turbulence modelling. Are you validating the code with some reference result.
If yes, Before going for preconditioning, you can check for your implementation, you can try AUSM+ or SLAU2 scheme which take into account for low speed (then you may not need a preconditioning). Preconditioning is basically used with a density-based formulation for simulating low Mach number flow, i.e. incompressible flows with desity-based algorithm. |
Pressure Driven Supersonic Flow in Converging-Diverging Nozzle | cdm | OpenFOAM Running, Solving & CFD | 7 | August 28, 2019 01:37 |
How to get the total pressure in the UDF? | zgzhai | Fluent UDF and Scheme Programming | 3 | September 24, 2018 16:12 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
replacing of shock tube high pressure part with a boundary condition for low pressure | immortality | Main CFD Forum | 0 | May 2, 2013 13:30 |
Unsteady pressure differential between inlet and outlet of the pipe for single phase | joshi20h | FLUENT | 0 | September 26, 2012 12:41 |
