July 30, 2015, 09:43 |
Famous Fluid Equations Are Incomplete
Here is an intro to a paper by Marshall Slemrod
https://www.quantamagazine.org/20150...er_Feb_27_2015 The paper is here http://www.mmnp-journal.org/articles...p201510p6.html and you can get a preprint here https://www0.maths.ox.ac.uk/system/f...xPDE_14.09.pdf Boltzmann equation implies the Korteweg equations and not the Navier-Stokes equations. The Korteweg equation is also a system of 5 equations (one mass, 3 momentum, one energy) and has dispersive terms apart from the usual Navier-Stokes terms. The above articles/paper talk of some physical situations where Navier-Stokes gives wrong solution but the Korteweg system gives the correct solution. These are all low density situations. We can get the Euler eqns in the limit of vanishing knudsen number only for regular solutions. So in general the Euler eqns are not the correct model for zero viscosity limit. Now what does this all mean for turbulence problem ? |
July 30, 2015, 09:48 |
Filippo Maria Denaro
Rep Power: 71 |
July 30, 2015, 10:08 |
Slemrod refers to papers by Gorban & Karlin and Saint-Raymond where they derive the Korteweg model starting from Boltzmann equation. This model is similar to Navier-Stokes but has additional Korteweg terms which are dispersive. If you accept Boltzmann as a good model of reality, then you get Korteweg and not Navier-Stokes.
July 30, 2015, 10:42 |
#4 | |
Rep Power: 71 |
yes, I see but what I mean is that classical NS are a model, they do not consider many effects .. and I think that even including the dispersive terms in a computation they are not relevant in changing the solution for many flows...If I am right, dispersive term should be relevant when capillarity effect are present, this is the case of microfluidic. |
July 30, 2015, 11:41 |
Rep Power: 71 |
do you know some DNS performed solving a 3D Korteweg-like model and compare relevant differences in the solution? I am quite curious to know if someone explored that...
July 30, 2015, 12:09 |
#6 | |
To quote Slemrod
This is all new stuff to me, so I dont know what people have done in terms of solving the Korteweg system and what it means for turbulence. |
July 30, 2015, 12:20 |
#7 | |
Rep Power: 71 |
yes, as I can remember, microfluidic is the typical framework where such effect happens... however, owing to the very small scales, no relevance on turbulence is highlighted in such problems... for standard turbulence, the question would turn to be if the smallest, viscous scales of turbulence, say behind the Taylor microscale, would have a new behaviour due to inclusion of capillarity. That could have great interest since an SGS model in LES should also take into account such effects |
August 1, 2015, 09:07 |
August 1, 2015, 09:42 |
#9 | |
Rep Power: 71 |
I think the same, too... however, the question to be explored could be if some capillary effects cohexist at small scales and are somehow relevant in the dynamic of the largest...I doubt |
Multiphase simulation of bubble rising | Niru | CFX | 5 | November 25, 2014 13:57 |
Coupling of state equations and fluid solver | rbprat01 | Main CFD Forum | 1 | January 18, 2012 13:21 |
Fluid Structure Interaction | Apollo | FLUENT | 8 | July 7, 2004 17:54 |
6 Degree of Freedom Navier Stoke Equations | Apollo | FLUENT | 0 | July 5, 2004 05:34 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
