Problems finishing implementation of 2D Linear-Strength Vortex Method (Airfoil)
Old   August 30, 2015, 15:53
Default Problems finishing implementation of 2D Linear-Strength Vortex Method (Airfoil)
Alexandros Kontogiannis
al3x is on a distinguished road
Hello everyone,
I would really appreciate any help to complete my script implementing a linear-strength vortex method as described by Katz and Plotkin in Low Speed Aerodynamics (Section 11.4.2 and Program no.7 in Appendix). This is my first script implementing a panel method and I have faced some (not only)programming difficulties.
So, I was trying to get a Cp plot of an airfoil but I always received a random fuzzy line (just garbage). It's been 3 days now that I'm trying to correct this and still no luck. BUT, in my surprise, I gave as input just the upper surface of the airfoil and I received the true Cp plot and the same for the lower. That being said, I can compute the two airfoil surfaces alone but if I input the full airfoil.dat file I get garbage.
Are the upper and lower vortex-sheets independent? The collocate points of the lower vortex-sheet should not be affected by the vortices of the upper vortex-sheet (and vice-versa)? It was my idea that the airfoil works as one vortex-sheet alone.. do I have to separate them?
Thanks in advance!
The links below correspond to the photos of the Cp plots with the two surfaces alone (correct) and the airfoil (fuzzy line - garbage):
Upper Surface Cp & Airfoil (S1210)
https://drive.google.com/open?id=0B8...0V4TlViYkNGT3c
Lower Surface Cp & Airfoil
https://drive.google.com/open?id=0B8...XQzZV8zbmkzV28
Airfoil Cp
https://drive.google.com/open?id=0B8...FVnZTNBNGRqSG8
al3x is offline   Reply With Quote
Old   August 30, 2015, 18:58
adrin
adrin is on a distinguished road
You clearly have a bug. Yes, the entire vortex sheet system should represent the body in question (not just its constituent parts). Are you sure you have a consistent coordinate system and your local grid-normals all point outward (or inward) all around? Have you tried a simpler problem (say potential flow over a cylinder) and looked at the matrix values? For example, are the row sums (or column sums depending on implementation) of the matrix giving you correct values?
adrin
adrin is offline   Reply With Quote
Old   August 31, 2015, 15:31
Yes adrin, I have evaluated the results with the vectors pointing outwards and inwards and all the other possible arrangements of normal and tangential vectors and I really can't make it work.. For evaluation I check the vortex-strength solution on a symmetrical airfoil for symmetry and I run in another tab of the terminal xfoil to crosscheck the Cp plots.
I almost even copy the Program no.7 (p. 562 ->Appendix of Katz and Plotkin "Low Speed Aerodynamics") and still doesn't work. Can anyone validate if this program works in Fortran (with a copy-paste from book) and let me know?
I will provide a link to the script if it's possible for anyone to check it and let me know of possible wrong implementations.
Script:
https://drive.google.com/file/d/0B8G...ew?usp=sharing
Old   September 1, 2015, 12:22
Matt
fluid23 is on a distinguished road
This looks like a simple numerical issue to me. I created a similar program for part of my thesis work a couple years ago. Check your math. I will look around later this evening and see if I can track down the code. Have you implemented any boundary layer methods yet or is this potential flow?
fluid23 is offline   Reply With Quote
Old   October 5, 2017, 10:56
Manoj
ManojM is on a distinguished road
I am facing a similar problem.
I am trying to develop a linear vortex panel code, following Katz and Plotkin. I am getting fuzzy CP distribution.
al3X were you able to solve this issue?
ManojM is offline   Reply With Quote
airfoil, panel, sheet, vortex
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
Linear-Strength Vortex Unsteady Panel Method (2D) Sonik_87 Main CFD Forum 18 February 23, 2020 09:16
Problems solving T Equation in separated flow using a second Order Closure Model pascool OpenFOAM Programming & Development 1 November 19, 2012 10:29
Inner non linear iterations and Newton method misabel Main CFD Forum 3 March 11, 2010 11:19
Has the pressure correction method problems? X. Ye Main CFD Forum 17 September 1, 1999 16:14
