Coupling inlet and outlets massfluxes in an enclosed circulation system
Old   October 6, 2015, 14:29
Default Coupling inlet and outlets massfluxes in an enclosed circulation system
Niels Bessemans
NielsB is on a distinguished road
Dear,
I am currently modelling the distribution of oxygen and carbon dioxide gas in a storage container for fruit.
Inside the storage container there is a pile of fruits. Also, there is a tubing system with an inlet and two outlets. The inlet is provided with a fan which sucks air inside the tubing system. The two outlets are positioned in the corners of the container to spread out the air.
Modeling regarding velocity:
Air speed at the inlet was measured experimentally and is specified at the inlet face of the tubing system to be x m s^-1. At each of the outlets, the mass flow rate of the container atmosphere is defined as massFlow()@Inlet/2. Which seems to work properly. The problem arises when modelling the mass transfer.
Modelling of the mass transfer:
At the inlet (=outlet in the model, since it is an outlet to my system), there is no need to specify the AV value or something about it, since CFX will just calculate it. The outlets are more difficult. What I actually want is to specify the mass flux for each of my additional variables at each of the outlets to be half of the mass flux that goes into the tubing system. However, I'm not able to find such an option in ANSYS 16.2 CFX module. I have tried to set the value of the AV's to the area average of the AV at the inlet using areAve(AV)@Inlet but this is not correct to do so. So what I am wondering is if anybody knows how to access or specify the massflux in CFX?
Looking forward to your reply!
Kind regards,
Niels
NielsB is offline   Reply With Quote
Old   October 8, 2015, 05:26
Niels Bessemans
Doe anybody have an idea if it is possible to specify cyclic massflux boundary condition in ANSYS CFX? In comsol it is possible. If not possible, does anybody have some experience writing some fortran routine for it?
Kind regards,
Niels
additional variable, mass flux
Cylindrical tank with a single inlet and two outlets samchance91 Main CFD Forum 0 September 28, 2015 08:39
One inlet and two outlets mingzhao OpenFOAM Running, Solving & CFD 1 July 16, 2015 18:03
Two pressure outlets, no inlet??? LukeFullard ANSYS 0 August 2, 2012 21:43
