Multi-block grids references
Old   November 24, 2008, 05:16
Default Multi-block grids references
siw
I'm making a multi-block structred grid of an aerofoil with deployed slat and flaps. Any one know of some good references for this? Normally, I'd make an unstructred grid but a multi-block structred has been requested. My main concern is making blocks around the high-lift devices as they are close to the main aerofoil section.
Thanks.
Old   November 28, 2008, 00:48
Default Re: Multi-block grids references
Wifi Lee
Yes,I can do this.May I help you?
Old   November 28, 2008, 02:20
Balduin Bankerotti
http://www.gridpro.com/gridgallery/aerospace/wing.html
References for the finite volume method on unstructured grids old newbie Main CFD Forum 1 April 25, 2011 23:53
coupling and multi block meshing abdullahkarimi Siemens 1 November 11, 2010 02:20
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 02:58
Multi Block case. Constantinos Constantinou FLUENT 1 October 26, 2001 02:00
F90, modules and multi block Frank Muldoon Main CFD Forum 0 October 13, 1999 22:37
