To find whether a point lies inside or outside a curve defined by points
Old   November 2, 2015, 05:40
Default To find whether a point lies inside or outside a curve defined by points
casper
casper is on a distinguished road
Hello all,
I have a closed curve defined by points and not equation. I have find if a point lies inside the curve or outside. Is there a way to do this without having to fit an equation to the curve?
Here by points I mean computational nodes and the points on the curve need not coincide with the nodes.
casper is offline   Reply With Quote
Old   November 2, 2015, 07:25
JulianP is on a distinguished road
have a look here: https://en.wikipedia.org/wiki/Point_in_polygon
In short: Draw an infinite horizontal line in one direction beginning at the point in question. Now, count how often this line intersects the edges of the polygon. If you get 0 or an even number, the point lies outside. If you get an odd number, the point lies inside.
You only have to think about what happens when your point lies on an edge of the polygon.
JulianP is offline   Reply With Quote
Old   November 2, 2015, 23:53
casper
Hey,
This would be easy if we had the equation of the curve. In my case, the curve is defined by points and cannot be very easily fit into an equation.
Old   November 3, 2015, 02:35
Hello casper,
this is a point-in-polygon test. In a polygon the discrete points are connected by edges, which are simple straight lines.
Have a look here: https://www.ics.uci.edu/~eppstein/161/960307.html You can find some pseudo-code there.
Don't think too complicated
Old   November 3, 2015, 03:48
casper
Thats awesome! Also the link has detailed description for the procedure.
Thanks Julian
[snappyHexMesh] .STL: non-closed manifold surface giulio.topazio OpenFOAM Meshing & Mesh Conversion 32 November 25, 2016 03:15
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
How to determine a point is inside a tetrahedral? G.P. Xia Main CFD Forum 16 January 12, 2000 11:15
