y+ in a train surface
Old   January 26, 2009, 04:10
Default y+ in a train surface
Lottar
Hi!!
I'm working with a train model and i wanted to prepare the grid in order to have a y+ close to the surface equal to 100 (because of other studies performed and capacity...) anyway, i know that the computation of the size cell should be like that:
d/2=y=(y+·viscosity)/u_tao
where u_tao is calculated as sqrt(Cf·u_infinity/2)
my question is what is Cf and how to get this?? i know there are expressions depending of the flow (laminar or turbulent) but for a U_infinity=40 m/s which one should i use???
thanks in advance!!!
Lottar
Old   January 26, 2009, 04:57
Default Re: y+ in a train surface
Magellan
Hi Lottar
u+ and y+ non-dimensional forms are usually used for turbulent flows, with the definitions:
u+ = u_mean/u_star
y+ = y*u_star*rho/mue
with wall friction velocity u_star = sqrt(tau/rho)
and tau = mue*du/dy @ the wall (y=0)
The link to the skin friction is: Cf = 2*tau/(rho*U^2)
You should calculate also the Reynolds number (Re=rho*L*U/mue) to see what flow regime you have (laminar or turbulent). But as I mentioned at the beginning u+ and y+ values are mostly used for turbulent flows, so far as I know.
Hope this helps!
M.
Old   January 26, 2009, 05:06
Lottar
Thanks Magellan!!
But in this case is difficult to know which is du/dy at y=0 and so on, so the best way to get y+ i found was with
Cf=0.0588/Re^(1/5) since a turbulent boundary layer as u say will appear and the surface on the train could be considered as a flat plate...
what do u think guys?
cheers!
Old   January 26, 2009, 07:25
Timon
Hi Lottar,
Just make a coarse approximation, create a grid accordingly, perform a simulation and adjust your grid based on the computed and desired y+ values.
Old   January 26, 2009, 17:14
Lottar
Ok, i'll try in this way...thanks Timon!
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
