Jacobian
Old   February 25, 2009, 20:07
Default Jacobian
Shuo
When transforming equation into curvilinear system is the boundary condition applied in physical/ computational space?
Shuo
Old   February 27, 2009, 14:16
Default Re: Jacobian
Harish
The answer depends on the kind of transformation that you employ. When you transform the velocity components you can use covariant or contravariant transformation or you can just assume each component as a scalar and perform the transformation in the usual way.
Lets consider the case of Euler eq. The BC you set is U.n=0. If the grid is curvilinear and you perform coordinate transformation from cartesian (u,v) to curvilinear (assume u1,u2). In the transformed space because of no penetration condition
u2=0 and u2 is related to cartesian by u2= u dphi/dx+ v dpi/dy and using u2=0 you get the BC.
Check the 4th Aeroacoustic workshop on benchmark problems (available from NASA server ) and look for papers by Visbal and Scott.
Harish
What's the use of Jacobian in Grid Generation? Pete Main CFD Forum 5 April 6, 2014 21:23
Jacobian of 1D Euler Equation of Gas Dynamics Simplicity. Main CFD Forum 3 September 6, 2011 14:12
Viscous Flux Jacobian bearcat Main CFD Forum 10 March 11, 2010 17:14
how to compute the jacobian of a line ztdep Main CFD Forum 0 June 1, 2007 07:04
Multigrid and Jacobian biga Main CFD Forum 2 July 25, 2001 23:08
