comparison of CFD & WT
Old   January 11, 2000, 02:48
Default comparison of CFD & WT
ROOH-UL-AMIN KHURRAM
I am mainly involved in the validation work. I found that the Cn, Cm values are within 5% to the Wind Tunnel. But the drag is "OFF". The main problem is in Base Drag estimation. I have tried various TURBULENCE MODELS without success. If any one of you have successfully matched the drag coefficient, please contact me. Any suggestions about the selection of TURBULENCE MODEL to simulate wake,would be helpful. I am using 10 degree cone as the standard shape.
Old   January 11, 2000, 13:13
Default Re: comparison of CFD & WT
clifford bradford
you may find that your results are quite typical. i was told by one of my professors that he never saw navier stokes drag predications that were good. typically lift and moment which are aminly due to pressure forces are good but the drag is usually off. many turbulence models were developed for stream line bodies so they probably won't be good for your cone. hopefully others will respond so you and i can see their tips.
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
comparison of CFD results with reality chouer CFX 0 October 31, 2005 13:30
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 15:01
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
COMPARISON BETWEEN VARIOUS CFD SIMULATION APPROACHS OF REACTIVE TURBULENT FLOWS mounir Main CFD Forum 4 March 3, 1999 12:07
