March 24, 2016, 05:34 |
Pressure Outlet - Effect of domain
Bineet Mehra
Rep Power: 12 |
Hello
I am modeling a conjugate heat transfer problem in STARCCM. Inlet - Velocity Inlet Outlet - Pressure Outlet Flow - Laminar, Low R, Steady As i change the distance between the trailing edge of the fin and outlet, P-inlet keeps on changing. I started with very small distance between Trailing edge of fin and outlet and then kept on increasing it. I did 6 simulations with different distance between Trailing edge of fin and outlet. I expect constant P at inlet after some value of this distance between Trailing edge of fin and outlet but its not the case. Aim is to get pressure drop. The lateral boundaries around outlet are symmetry planes. There is no recirculation at the outlet. Any Suggestion ? Help Thanks |
March 24, 2016, 14:17 |
duri
Rep Power: 16 |
Please plot the pressure with distance and see the trend. It should converge to a fixed value. Pressure outlet need to be placed at a location where geometric effects and viscous effects are negligible. In subsonic flow, outlet boundary will hold the input pressure and adjust the inlet boundary pressure. If you don't know the static pressure at the outlet at given location, better to move as far as possible.
March 30, 2016, 05:31 |
#3 | |
Bineet Mehra
Rep Power: 12 |
Thanks |
April 5, 2016, 04:50 |
Bineet Mehra
Rep Power: 12 |
The distance from Trailing edge of the fin and the outlet section was not enough. P at inlet not changing now for distance between TE of fin and outlet section more than 4L, L is the length if the fin.
Thanks |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 10:40 |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Pressure Outlet - Effect of domain | bineet_aero | STAR-CCM+ | 3 | April 5, 2016 04:51 |
the static pressure at one outlet is negative? | yuhehuan | Main CFD Forum | 7 | August 15, 2013 21:01 |
pressure inlet & outlet. help ASAP Plz | engahmed | Main CFD Forum | 0 | June 13, 2010 15:34 |
