April 5, 2016, 23:31 |
Viscosity limit between turbulence models
sunil
Rep Power: 13 |
Hello every,
I am curious to know that is there any viscosity limit bellow which we can use boussinesq hypothesis turbulence models (SA, ke, kW) and above which we have to use RSM turbulent models. Is there any dimensional number to identify these difference for quickly selecting turbulent model. Thank you
Regards, Sunil |
April 6, 2016, 03:17 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
a physical reasoning guides to consider the minimum value to zero as negative values would imply an anti-diffusion effect that is somehow related to a backscatter of energy |
April 6, 2016, 04:17 |
sunil
Rep Power: 13 |
Hi denaro,
Can you please explain it. I am not understanding anti- diffusion effect and back scatter of energy.
Regards, Sunil |
April 6, 2016, 04:20 |
Rep Power: 71 |
immagine the diffusive flux of momentum, for positive values of the viscosity, it acts to smooth gradients. Conversely, an anti-diffusion due to negative values of the viscosity will tend to further increase a gradient.
April 6, 2016, 10:28 |
sunil
Rep Power: 13 |
Hi denaro,
Thanks for your reply.
Regards, Sunil |
Turbulence and viscosity of non-Newtonian Fluids | David | FLUENT | 9 | October 30, 2023 04:55 |
Eddy Viscosity Models and Reynolds Stress Models | JuPa | CFX | 1 | August 20, 2013 18:56 |
turbulence models? | haider | FLUENT | 0 | March 7, 2006 23:58 |
Turbulence Models and external flow. | Alan | FLUENT | 3 | November 22, 2005 04:46 |
How to set phase dependent turbulence models? | J.Yang | CFX | 2 | August 29, 2002 15:39 |
