April 28, 2016, 00:40 |
Turbulent boundary layer and separation
Nick
Rep Power: 15 |
Hi guys,
I've simulated the flow over an airfoil and have a more fundamental question to ask. Can the boundary layer, say over an airfoil, become turbulent thru natural transition without flow separation? I think the answer is positive. If you could shed more light on this, it would be great. Also, how would one verify the boundary layer characteristics, as in whether it's laminar or turbulent. Is checking contours of intermittency the only way? Or should you check the boundary layer velocity profile (mean) against one for a flat plate? But here's there's a pressure gradient so is this comparison fair? Thanks Nick R. |
April 28, 2016, 01:59 |
david
Rep Power: 13 |
you could look at the shape factor which, dare i say characterizes the fullness of the profile. the shape factor is just the ratio of your displacement thickness and the momentum thickness. Blasius laminar shape factor is around 2.5. this number will decrease as you increase Reynolds number.
One other characteristic ( more of a necessary but not sufficient condition) of instabilities in the flow is the inflection in the velocity profile. |
April 28, 2016, 02:30 |
Filippo Maria Denaro
Rep Power: 71 |
what do you mean exactly? natural transition to turbulence (immagine the flow over a flat plate) leads to create unsteady vortical structures, very small near to wall, so that by definition you have separation. Maybe I did not understand your question...
April 28, 2016, 23:52 |
Nick
Rep Power: 15 |
But in that case there's no inflection in the mean velocity profile (flat plate) is there? So there's no boundary layer separation.
April 28, 2016, 23:58 |
#5 | |
Nick
Rep Power: 15 |
Thanks. For calculating the boundary layer thickness, is the edge of the boundary layer in the case of flow over a foil, say over the suction side, still 99percent of the free-stream speed? Or is it different since the flow speeds up locally? |
April 29, 2016, 03:16 |
Rep Power: 71 |
April 30, 2016, 21:15 |
Nick
Rep Power: 15 |
May 1, 2016, 03:23 |
Rep Power: 71 |
I think that in regular operating condition (low angle of attack) the mean velocity profile does not show inflection
Wing's laminar to turbulent boundary layer separation | joaofl | OpenFOAM Running, Solving & CFD | 0 | August 8, 2014 14:03 |
Turbulent viscosity ratio limited to 1.10^5 in boundary layer ingestion | loicflouriot | FLUENT | 0 | May 27, 2012 07:31 |
Boundary layer separation | thegodfather | Main CFD Forum | 9 | April 17, 2012 08:54 |
Modelling Boundary Layer Separation from A Sphere | Nick | Main CFD Forum | 0 | October 7, 2006 05:27 |
Boundary Layer Flow Paradox | Wen Long | Main CFD Forum | 3 | September 24, 2002 08:47 |
