Scaling the mesh in FLUENT and its possible consequences |
May 2, 2016, 14:16 |
Mario Alberto
Rep Power: 10 |
What would it be the consequence of scaling a mesh 10 times in FLUENT? Does it affect the convergence or the time of convergence? As I understand, the amount of cells, aspect ratio and the rest of the mesh characteristics should remain the same, therefore the time of the calculation should be the same. Am I right? I am running some simulations of heat transfer effect on aerodynamic performance of airfoils. So far, I've worked only with 2 meter chord airfoils, but I'd like to study the same effect in smaller airfoils (down to a 20 cm airfoils). Any insight into this would be welcome. Thanks in advance! |
May 2, 2016, 14:27 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
if you scale only the lenght, the Reynolds number scales accordingly and the physics is different |
May 3, 2016, 02:54 |
Alex
Rep Power: 46 |
...which in turn will affect convergence behavior and simulation time.
airfoils, fluent, heat transfer, scale |
