Interesting pressure and velocity contours
Old   May 5, 2016, 10:09
Default Interesting pressure and velocity contours
windywires is on a distinguished road
I've been analysing the 2D flow over a not-quite-circular cylinder in ANSYS Fluent. The analysis has been transient and run long enough to produce this lift coefficient plot. It oscillates at the vortex shedding frequency as would be expected and its time-average gives a lift coefficient of -0.307.
With this downwards lift in mind, I don't understand these total pressure and velocity magnitude plots. There seems to be higher pressure AND higher velocity on the underside of the shape, which would be impossible according to Bernoulli. Also, wouldn't the higher pressure underneath suggest upwards lift and give a positive lift coefficient? And what can can we interpret from the fact that the shed vortexes take a path at an angle to the flow?
I'd really appreciate your thoughts
windywires is offline   Reply With Quote
Old   May 5, 2016, 11:37
david
davidwilcox is on a distinguished road
Let's have a look at your dynamic and static pressure distribution *wink*
davidwilcox is offline   Reply With Quote
Old   May 5, 2016, 12:06
Thanks very much for the reply, David. I don't actually have access to the data right now (it's saved on a lab computer) but I'm assuming you mean that you'd expect there to be an area of high dynamic pressure and low static pressure on the underside of the shape? That makes sense!
Any ideas why the vortices move upwards? Is this because the shape is being 'lifted' downwards?
Old   May 5, 2016, 13:02
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
could you better define "non-quite-circular"?
FMDenaro is offline   Reply With Quote
Old   May 5, 2016, 13:10
It's got two notches in it - the cross-section can be found here
Old   May 5, 2016, 13:20
Filoppo, it's a circle with notches along both sides on the upper half, as shown here. I hope that helps
aerofoil, bluff bodies, contour plot, cylinder flow, lift coefficent
Pressure Inlet VS velocity Inlet difference Mohsin FLUENT 9 January 4, 2021 10:34
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
