Time derivative of pressure in low mach number approximation
Like Tree1Likes
  • 1 Post By FMDenaro
Old   June 16, 2016, 05:34
Post Time derivative of pressure in low mach number approximation
SAM
hnemati is on a distinguished road
Dears
I have a question regarding the time derivative of pressure in low-Mach number approximation of NS equations. Referring to the work " Numerical study of a channel
flow with variable properties" done by Nicoud, depending on the whether the simulation system is closed or open, the time derivative of pressure can be defined as ... (see the equation 8 of his paper) for closed system or zero for open system.
Could somebody tell me why for open system this is zero?
Thank you all
hnemati is offline   Reply With Quote
Old   June 16, 2016, 07:05
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by hnemati View Post
Dears
Thank you all
I suppose that is due to the fact that it is assumed to be the (constant) atmospheric pressure
hnemati likes this.
FMDenaro is online now   Reply With Quote
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 18:32
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 14:49
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
