July 20, 2016, 16:40 |
Different Leading edge curvatures.
Pringles
Hello everyone,
I am new to CFD tools. I started working on different airfoil geometries in SolidWorks. I am currently looking for ways to design different Leading edge curvatures to get max L/D ratio. I need an idea to design the same. Please help.! |
July 20, 2016, 18:11 |
Administrator
For subsonic airfoils a good start is something close to parabolic in the LE region, an even better start is probably to start looking at classical airfoil shapes before you start experimenting on your own. Theory of Wing Sections by Abbott and Doenhoff is a good book on classical airfoils. There are 50 years of experience from airfoils in that book and you need to stand on the shoulders of giants to reach higher. CFD on airfoils is another topic that can also be tricky. Do not trust the results of your fully turbulent general purpose CFD code.
July 23, 2016, 14:55 |
Pringles
Thanks jola, you were comments were really helpful. And I did go through the book you mentioned.
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Unusual turning angle ahead of blade leading edge | carnage2121 | Main CFD Forum | 0 | May 20, 2013 19:11 |
Y-Plus values at aerofoil leading edge and trailing edge at high incidence | Engr07 | Main CFD Forum | 4 | June 29, 2012 10:42 |
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge | TWaung | CFX | 2 | February 16, 2010 08:11 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
