Mass flow rate calculation based on the data of Xu and Froment Kinetics.
Old   August 29, 2022, 09:33
Default Mass flow rate calculation based on the data of Xu and Froment Kinetics.
Vinay Chandrakar
chinu007 is on a distinguished road
Hello Everyone,
I would like to calculate mass flow rate of feed inside the reactor based on the data given for Xu and Froment Kinetics.
Given data,
Pressure=10bar
Temp=673K
H2/CO2=1
W=weight of catalyst=0.4gm
Reactor dia=1.07cm
Reactor length=10cm
I am trying to plot, Figure 4 and Figure 5 from the paper "Methane Steam Reforming, Methanation and Water-Gas Shift: 1. Intrinsic Kinetics".
In this figure author plotted the graph for certain temp where x-axis denotes (W/F_CO2) and y-axis denotes conversion.
In plot x-axis varied from 0-0.5, I tried assuming (W/F_CO2=0.1) and then calculated F_CO2=4 mol/hr and then F_H2=4 mol/hr because H2/CO2=1, then F_total=F_CO2+F_H2, from this molar flow rate I used mixture molar mass to calculate mass flow rate of feed.
My graph pattern is correct but values which I am getting is different and I think I am doing some calculation mistake in mass flow rate because code is correct.
Can anyone help me with this problem. Thanks in advance.
chinu007 is offline   Reply With Quote
chemical kinetics, chemical reaction, mass flow rate bc
