July 27, 2016, 11:38 |
basic question
abi
Rep Power: 9 |
This question just popped in my head but i couldn't reconcile the contradiction. Assuming water ( incompressible assumption) flow (developed flow) through a horizontal pipe with a constant diameter, by some head gradient driving force (neglecting head losses) between the pipes edges. looking at 2 arbitrary cross sections along the pipe and applying bernoulli's principle i can conclude that non of the energy components change (pressure,velocity,gravitational potential). but i also been taught that fluid flows from high to lower head, but those two arbitrary cross-section appear to have the same head...or i got something wrong?
Thanks for the help! |
July 27, 2016, 11:45 |
Filippo Maria Denaro
Rep Power: 71 |
a simple 1D model equation for your case:
du/dx= 0 (continuity) u*du/dx + (1/rho)*dp/dx = 0 (momentum) therefore u=constant is a solution that satisfies the dp/dx=0 constraint. In a real flow pipe, the condition dp/dx<0 is conseguent to the balance with viscous forces. |
July 27, 2016, 12:08 |
thanks for thr quick response
abi
Rep Power: 9 |
I still didnt quite get it. By just looking at these two cross sections, if the pressure gradient is 0 aand its horizontal what is the flow driving force ?
July 27, 2016, 12:16 |
#4 | |
Rep Power: 71 |
if you assume no energy dissipation (inviscid flow) the equations simply say that if a flow already has a constant velocity (and constant kinetic energy), the energy is conserved and the flow moves indefinitely without pressure gradient. |
[Other] very basic question about createPhi.H | feldy77 | OpenFOAM Meshing & Mesh Conversion | 2 | November 22, 2011 08:16 |
Basic question to buoyantBoussinesqPisoFoam | kriz | OpenFOAM | 2 | June 12, 2010 03:35 |
Basic Question | Abhi | FLUENT | 1 | August 4, 2007 08:07 |
Basic question: UDF for wall heat flux | Carl | FLUENT | 1 | August 5, 2006 19:01 |
A Basic Question on ducted Flows! | CFD User | Main CFD Forum | 4 | January 8, 2005 06:17 |
