Flow through throttle valve in NX flow
Old   August 10, 2016, 11:43
Default Flow through throttle valve in NX flow
Ashwath Suresh
Ashwath is on a distinguished road
Send a message via Skype™ to Ashwath
Hello all,
I am using Siemens NX 10. I have the hollow tube and the throttle valve is located at the center of the tubee. The boundary conditions are given as:
1.)inlet flowvolume : 560m^3/h
2.)Temperature at inlet : 0'c
3.)static pressure at outlet : 1 bar
4.) Angle of throttle valve : 0 to 90 in 10'c steps
Target:
1. Determine aligning torque of the throttle valve
2. Determine the pressure drop for each position of the throttle
3. transfer of the results in an XY plot
4. transfer of the forces on the throttle in a FEM simulation (determination of deformation and comparison voltage at the throttle valve)
I am confused to give the angle to throttle valve and to determine the aligning torque and pressure drop of throttle valve.
I have implemented the synchronous modeling such as promote and delete face options to create the polygon body. Did the meshing with 2d meshing(shell). Now I am struck up in giving the boundary conditions. Could anyone please help me.
Ashwath is offline   Reply With Quote
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 10:40
Two way FSI Aortic Valve / Blood Flow PhiSch FLUENT 3 October 18, 2016 14:24
Boundary conditions for flow in nozzle kgevers FLUENT 0 July 26, 2015 12:46
Simulation of air flow inside valve - FSI? Help! farianka Main CFD Forum 0 April 17, 2011 16:30
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
