Deferred Correction Convergence Problem
Old   September 14, 2016, 10:53
Default Deferred Correction Convergence Problem
Simon Hahn
Simon Smokes is on a distinguished road
Dear All!
My Name is Simon and I'm currently working on my mean flow solver for a SST-turbulence model. In order to ensure numerical stability I used the SIMPLER algorithm (pressure based) and in my momentum equation TVD by applying deferred correction (DC). My problem is related to the boundary condition of the first node referring to the 'inlet flux'.
#node1: u_mom = source_term/a_P
=> source_term = friction_losses + DC + inlet_flux * inlet_velocity
=> inlet_flux = rho * A_inlet * u_inlet
=> inlet_velocity = u_inlet
With the first initial guess of the velocity field I obtain the 'momentum velocity field u_mom' which is reduced by the friction losses represented by the according source term. Due to the momentum residual of 0.0013 the loop is run a second time to further correct my velocity field.
When I go now in the second run of the DC loop the first node of my 'limited velocity field' and obtain the new momentum velocity, my first node differs from the others and oscillation and divergence starts.
Numerical valuesn (example):
u* = [1 1 1 1 1];
u_mom(1) = [0.8 0.8 0.8 0.8 0.8]
u_mom(2) = [0.8 0.6 0.6 0.6 0.6]
The problems araise from the inlet condition: a fixed value for inlet flux and velocity cause problems as well as setting the inlet velocity equal to u_mom(1).
Since years I work on CFD by applying various techniques and I would really appreciate an answer to my problem and support you as well in any case!
Simon Smokes is offline   Reply With Quote
a problem with convergence in buoyantSimpleFoam skuznet OpenFOAM Running, Solving & CFD 6 November 15, 2017 12:12
Centrifugal pump OpenFOAM, convergence problem, ANSA model RDD OpenFOAM Running, Solving & CFD 0 July 5, 2014 09:12
Convergence Problem in Axisymmetric Periodic Flow atheresia FLUENT 3 February 10, 2014 03:00
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 10:47
CONVERGENCE PROBLEM - oil boiler MM FLUENT 1 February 15, 2007 05:24
