September 18, 2016, 02:00 |
How to compute rotation of rotation of V
Dear friends:
I am implementing the following pressure boundary condition for 2D incompressible flow problem accordind to the paper of KARNIADAKIS"High orer splitting methods for incompressible NS equations" Could you please give me some suggestions about the computation of term for 2D problems regards |
September 18, 2016, 03:58 |
Filippo Maria Denaro
Rep Power: 71 |
Should be more simple if you consider that in 2D the curl of U is simply the vorticity that has only one component along the normal-to-plane direction.
So, you can first compute the vorticity field zeta and then you have to discretize curl (k zeta). The result is projected along the unit vector n. The way in which the derivatives are discretized depends on the grid arrangement and accuracy requirement. |
Compute Cluster with diskless compute nodes | Pauli | Hardware | 0 | October 6, 2015 16:48 |
Fluent rp var to modify rotation speed of a boundary | QBeast | FLUENT | 2 | August 12, 2015 15:58 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
Axis of rotation for centrifugal compressor | Mattia | FLUENT | 4 | October 22, 2007 11:05 |
