November 7, 2016, 02:25 |
CFD(FVM) Code of the problem
Ramakant Gadhewal
Location: Chemical Engineering,National Institute of Technology,Warangal (T.S.),India
Rep Power: 16 |
Dear all
I need this CFD code of the given problem.If anybody CFD code of the problem please try to share with me. my e-mail id:ramakantgadhewal@gmail.com Thank you With Best Regards Ramakant Garhewal |
November 7, 2016, 07:31 |
Michael Prinkey
Rep Power: 25 |
We don't do homework problems? Most of us already have done them--all of them. Several of us *assign* them to students. If you have a specific question about how to write your own code, please ask. But there are no shortcuts to learning this topic--you have to do it yourself.
November 7, 2016, 10:19 |
#3 | |
Arjun
Rep Power: 34 |
What he said plus if you want hint look into patankar's book or malalasekera's book. They have worked example all you need to do is code it. Try it is not difficult and plus what you will learn will stay with you a long time. There is no learning like learning by doing. |
November 7, 2016, 13:52 |
Lucky
Rep Power: 66 |
I echo the sentiments above.
This isn't even a Fluent problem. If done in Fluent you would be solving the heat diffusion equation and not the fin equation. It's also a really simple problem and is really great for learning the FVM technique. I admit I did not appreciate how FVM works until I did it myself. This is a really simple problem! 1D steady fin equation. It can hardly get much easier than this. This is also a very robust problem, it's extremely well-behaved and numerically stable. It doesn't even require a complicated code. Just discretize the governing equation in the FVM sense. Integrate the governing equation over a control volume, use the Divergence Theorem to convert the volume integral of a divergence term into a surface integral of fluxes. Then discretize the temperature gradient at the faces using your favorite discretization scheme (backward differencing, forward differencing, central differencing). Do this for all cells~ Notice the pattern! All the interior cells will have the same structure. The boundary cells will have slightly different terms. i.e. you only need to do the left, right, and one interior cell to recognize the pattern. If you are not imaginative, then you might need to do it for all cells. Setup the linear system of equations (writing it in matrix form can help the pattern fall out). If you use central differencing, you'll get a tri-diagonal system. Then it's just a matter of solving the system of linear equations (inverting the matrix). Tri-diagonal algorithm works wonders. Matrix form just helps to visualize, if you can solve it without going into matrices, then kudos. This final step, solving the system of linear equations is what needs to be coded. You basically need to write a code that systematically assembles the coefficient matrix and then solve it. If you have trouble, just do it on the simplest case with only 3 cells (the left boundary, 1 interior cell, and the right boundary cell). Hopefully you can invert a 3x3 matrix (or can solve a linear system of 3 equations with constant coefficients). You just need to codifiy this procedure for however many cells you need. |
code for SIMPLE algorithm - 2D Lid driven cavity flow problem - Collocated grid | h_amooie | OpenFOAM Programming & Development | 1 | January 22, 2022 11:33 |
custom code compilation error: library linking problem | nadine | OpenFOAM Programming & Development | 5 | October 10, 2014 09:58 |
Problem in k-eps turbulence code in complex geometry | sontukaku | Main CFD Forum | 2 | December 28, 2010 00:44 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
What is the Better Way to Do CFD? | John C. Chien | Main CFD Forum | 54 | April 23, 2001 08:10 |
