Question about Mac-Cormack method in Anderson? |
October 23, 2019, 22:49 |
Mandeep Shetty
Rep Power: 10 |
As given in Chapter 7 of "Computational Fluid Dynamics, the basics with application" by -J.D.Anderson, the non-dimensional CD nozzle length is calculated as x/L, where L is the total length of the nozzle. But when presenting the results, the non-dimensional length varies from 0 to 3. Shouldn't it vary from 0 to 1? |
October 24, 2019, 00:29 |
Mandeep Shetty
Rep Power: 10 |
Can anyone confirm if this is a mistake or if there is a mathematical logic behind this?
October 24, 2019, 08:29 |
Filippo Maria Denaro
Rep Power: 71 |
October 30, 2019, 16:21 |
Matt
Rep Power: 17 |
I think if you look at A/A* you will see that the throat (A/A*=1) occurs at x/L = 1.5. This means that x/L=1 is not the exit. If you look at the initial conditions (Fig 7.8) he plots 'non-dimensional distance' that goes 0 to 3, inlet-outlet with throat at 1.5. I think you would get the same result if you non-dimensionalize with x/L=1 at the exit. He even notes after defining the initial shape of the nozzle (Eq. 7.73) that x=1.5 is the throat so that convergence is x < 1.5 and divergence is x > 1.5.
Its an odd mathematical choice to be sure and seems to be totally arbitrary on his part. Last edited by fluid23; October 31, 2019 at 08:23. |
cfd books |
Question about stage interface method between unequal interface heights. | electra0614 | CFX | 0 | May 20, 2019 04:09 |
mac cormack scheme | airfoil | Main CFD Forum | 0 | August 2, 2006 06:57 |
a question about Monte Carlo Method | Mindy | Main CFD Forum | 0 | September 16, 2002 21:30 |
Mac Cormack scheme and use of PML boundary conditi | vineet kshirsagar | Main CFD Forum | 1 | January 13, 2002 01:46 |
divergence in MAC Method | Maciej Matyka | Main CFD Forum | 2 | December 19, 2000 10:43 |
