Control function in Poisson eqtion grid generation? |
January 8, 2017, 01:53 |
Anh
Rep Power: 11 |
Hi everyone,
I tried to make the c-grid over NACA foil by using the Poisson eq. First, the distribution of grid point on boundary is specified and fixed by stretching function. Next, internal grid point is specified by tranfinte interpolation. Next, the control function in boudary is calculated based on the the fixed grid at boundary and of course they are fixed value. The control function in internal point is calculated based on the linear interpolation of the control function at boundary as paper of Thompson. Then the Poisson eq. is solved However, the grid that I did con not force the grid close to the foil wall. I dont know why it is happened. In here, the grid point is stretched to the nuy=0 and xi=0.5 (nuy and xi is the diection in computation coordinate). But it seem to large grid space from the wall as in the pictures Anyone has experiency on this proplem please help me?? Thank you. Below is my code: !c !C************************************************ *************** !C************************************************ ******************** PARAMETER(ni=301,nj=70) IMPLICIT REAL*8 (a-h,k,l,o-z) !c dimension x(ni,nj),y(ni,nj),& x1(ni,nj),y1(ni,nj),& phi(ni,nj),pha(ni,nj) !c pai=4.*atan(1.) ! Naca 4-rigid constant tf = 0.15 ac0= 0.2969 ac1=-0.126 ac2=-0.3516 ac3= 0.2843 ac4=-0.1015 c = 30./1000 ! Number of point in each domain ni1= 101 ni2= 51 ! Domain Boundary Length ac= 5.*c bc= 3.*c oc= 5.*c ! Stretch constant alf = 5. alfy= 5. ! Boundary in X-direction ! domain 2 do i=1,ni2 dxi=1./(ni2-1) xi =dxi*(i-1) a1=exp(alf*xi)-1 !!stretching grid at boudary a2=exp(alf)-1. x(ni1+i-1, 1)=oc*a1/a2+ac y(ni1+i-1, 1)=0. x(ni1+i-1,nj)=x(ni1+i-1,1) y(ni1+i-1,nj)=bc end do ! domain 1 do i=1,ni1 dxi=1./(ni1-1) xi =dxi*(i-1) xi0=0.0 a1=exp(alf*xi)-1 a2=exp(alf)-1. xc=c*a1/a2 y(i,1)=c*tf/0.2*(ac0*(xc/c)**0.5+ac1*(xc/c)+ac2*(xc/c)**2& +ac3*(xc/c)**3+ac4*(xc/c)**4) x(i,1)=xc+ac-c ! a1=exp(alf*xi)-1 a2=exp(alf)-1. xc=ac*a1/a2 x(i,nj)=xc y(i,nj)=bc*sqrt(1.-((ac-xc)/ac)**2) enddo ! do i=1,ni1+ni2-1 x1(i, 1)=x(ni1+ni2-1-i+1, 1) y1(i, 1)=y(ni1+ni2-1-i+1, 1) x1(i,nj)=x(ni1+ni2-1-i+1,nj) y1(i,nj)=y(ni1+ni2-1-i+1,nj) end do ! Full domain in X-direction ini=ni1+ni2-1 do i=1,ini x1(ini+i-1, 1)= x(i, 1) y1(ini+i-1, 1)=-y(i, 1) x1(ini+i-1,nj)= x(i,nj) y1(ini+i-1,nj)=-y(i,nj) end do do i=1,ni x(i, 1)=x1(i, 1) y(i, 1)=y1(i, 1) x(i,nj)=x1(i,nj) y(i,nj)=y1(i,nj) end do ! boundary eta direction do j=1,nj eta=1./(nj-1)*(j-1) a1=exp(alfy*eta)-1. a2=exp(alfy)-1. x( 1,j)=ac+oc x(ni,j)=ac+oc y( 1,j)=bc*a1/a2 y(ni,j)=-y(1,j) end do ! Tran Finite Inter. do j=2,nj-1 do i=2,ni-1 eta=1./(nj-1)*(j-1) xi =1./(ni-1)*(i-1) x(i,j)=(1.-xi)*x(1,j)+xi*x(ni,j)+(1.-eta)*x(i,1)+eta*x(i,nj)& -(1.-xi)*(1.-eta)*x(1,1)-(1.-xi)*eta*x(1,nj)& -xi*(1.-eta)*x(ni,1)-xi*eta*x(ni,nj) y(i,j)=(1.-xi)*y(1,j)+xi*y(ni,j)+(1.-eta)*y(i,1)+eta*y(i,nj)& -(1.-xi)*(1.-eta)*y(1,1)-(1.-xi)*eta*y(1,nj)& -xi*(1.-eta)*y(ni,1)-xi*eta*y(ni,nj) end do end do !C ******************** ELIPTIC GRID ****************** ca1=0.06 ca2=-1000. cc1=2. cc2=10.36 dxi=1./(ni-1) det=1./(nj-1) xtemp=0. ytemp=0. omega=0.27 residual=1. do i=2,ni-1 xxi=.5*(x(i+1,1)-x(i-1,1))/dxi yxi=.5*(y(i+1,1)-y(i-1,1))/dxi xxxi=(x(i+1,1)-2.*x(i,1)+x(i-1,1))/dxi**2 yxxi=(y(i+1,1)-2.*y(i,1)+y(i-1,1))/dxi**2 phi(i,1)=-(xxi*xxxi+yxi*yxxi)/(xxi**2+yxi**2) xxi=.5*(x(i+1,nj)-x(i-1,nj))/dxi yxi=.5*(y(i+1,nj)-y(i-1,nj))/dxi xxxi=(x(i+1,nj)-2.*x(i,nj)+x(i-1,nj))/dxi**2 yxxi=(y(i+1,nj)-2.*y(i,nj)+y(i-1,nj))/dxi**2 phi(i,nj)=-(xxi*xxxi+yxi*yxxi)/(xxi**2+yxi**2) end do do j=2,nj-1 xet=.5*(x(1,j+1)-x(1,j-1))/det yet=.5*(y(1,j+1)-y(1,j-1))/det xeet=(x(1,j+1)-2.*x(1,j)+x(1,j-1))/det**2 yeet=(y(1,j+1)-2.*y(1,j)+y(1,j-1))/det**2 pha(1,j)=-(xet*xeet+yet*yeet)/(xet**2+yet**2) xet=.5*(x(ni,j+1)-x(ni,j-1))/det yet=.5*(y(ni,j+1)-y(ni,j-1))/det xeet=(x(ni,j+1)-2.*x(ni,j)+x(ni,j-1))/det**2 yeet=(y(ni,j+1)-2.*y(ni,j)+y(ni,j-1))/det**2 pha(ni,j)=-(xet*xeet+yet*yeet)/(xet**2+yet**2) end do 1001 continue do j=2,nj-1 do i=2,ni-1 residual=-10000. xxi=.5*(x(i+1,j)-x(i-1,j))/dxi xet=.5*(x(i,j+1)-x(i,j-1))/det yxi=.5*(y(i+1,j)-y(i-1,j))/dxi yet=.5*(y(i,j+1)-y(i,j-1))/det aj = xxi*yet-xet*yxi alpha = xet**2+yet**2 beta = xxi*xet+yxi*yet beta=0. gama = xxi**2+yxi**2 phi(i,j)=phi(i,1)+(phi(i,nj)-phi(i,1))*(j-1)& /(nj-1) pp=phi(i,j)*(xix**2+xiy**2) pha(i,j)=pha(1,j)+(pha(ni,j)-pha(1,j))*(i-1)& /(ni-1) qq=pha(i,j)*(etx**2+ety**2) ! x equation xtemp = (dxi*det)**2/(2.*(alpha*det*det+gama*dxi*dxi))& * (alpha/(dxi*dxi)*(x(i+1,j)+x(i-1,j))& + gama/(det*det)*(x(i,j+1)+x(i,j-1))& - beta/(2.*dxi*det)*(x(i+1,j+1)+x(i-1,j-1)& - x(i-1,j+1)-x(i+1,j-1))+(aj*aj)*(xxi*pp+xet*qq)) ytemp = (dxi*det)**2/(2.*(alpha*det*det+gama*dxi*dxi))& * (alpha/(dxi*dxi)*(y(i+1,j)+y(i-1,j))& + gama/(det*det)*(y(i,j+1)+y(i,j-1))& - beta/(2.*dxi*det)*(y(i+1,j+1)+y(i-1,j-1)& - y(i-1,j+1)-y(i+1,j-1))+(aj*aj)*(yxi*pp+yet*qq)) xtemp = omega*xtemp + (1.-omega)*x(i,j) ytemp = omega*ytemp + (1.-omega)*y(i,j) residual =max(residual,sqrt((x(i,j)-xtemp)**2)+sqrt((y(i,j)-ytemp)**2)) x(i,j)=xtemp y(i,j)=ytemp enddo !c x(1,j)=x(2,j) !c x(ni,j)=x(ni-1,j) enddo if(residual.gt.(1.d-6)) goto 1001 if(residual.le.(1.d-6)) continue !c ************************ MAKE TECPLOTFILE ************************ OPEN(13,FILE='test.tec') write(13,*) "VARIABLES = ", "X ", "Y " write(13,*) "ZONE I=", ni, ",J=",nj, ", F=POINT" DO j=1,nj DO i=1,ni write(13,1000) x(i,j),& y(i,j) ENDDO ENDDO CLOSE(UNIT=13) 1000 FORMAT(2E24.10) 100 FORMAT(I4.4) END |
foamToTecplot360 | thomasduerr | OpenFOAM Post-Processing | 121 | June 11, 2021 10:05 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
Latest news in mesh generation | Robert Schneiders | Main CFD Forum | 0 | March 2, 1999 04:07 |
