lid-driven cavity using Matlab
Like Tree3Likes
Old   November 27, 2006, 09:49
Default lid-driven cavity using Matlab
M.A
Does anyone happen to have a Matlab code for solving the 2-D lid-driven cavity problem in primitive variables (i.e. pressure and velocity)? I will be so grateful, if you would be able to share it.
Thanks a lot.
Old   November 27, 2006, 10:38
Default Re: lid-driven cavity using Matlab
Andrew Hayes
does it have to be in primitive variables? It is not difficult at all using streamfuntion-vorticity, or streamfunction-velocity equations.
Old   November 27, 2006, 11:06
M.A
Thanks Andrew. In fact, I have already solved the problem using vorticity-streamfuntion formulation (which is quite easy), but I'm having some troubles implementing the SIMPLE algorithm (on staggered grid) for this problem in Matlab.
Old   November 28, 2006, 07:46
Andrew Hayes
I have you tried using the SIMPLER method? Just out of curiousity, how are you defining the pressure in the cavity? I was reading that the SIMPLE method cannot be used in all situations. Can it be used here? You might need to incorporate the under-relaxation constant.
Old   August 24, 2009, 02:51
idris is on a distinguished road
Send a message via Yahoo to idris
Originally Posted by Andrew Hayes
;46703
hi there, i know those equation, i applied the central difference method and put it in matlab code. The stream function i design it to be dimensionless and the same for the vorticity.
the problem is, after the coding, i can't get the nice solution.
i'm sorry to bother you all, but can you send me the code that's working because my code isn't. I just want to compare or to determine where is my code (matlab or fortran) went wrong. ok.
my email: sesenangje@yahoo.com
Thanx very much
idris is offline   Reply With Quote
Old   August 24, 2009, 09:15
Jonas T. Holdeman, Jr.
Jonas Holdeman is on a distinguished road
I have a Hermite FE code used in a paper to appear in IJNMF. It computes the velocity and the pressure as a function of the velocity.
Jonas Holdeman is offline   Reply With Quote
Old   August 26, 2009, 00:48
thanx very much, but mine in FD not FE. but if you want to send me the codes, it will be really nice of you. With the codes, i can validate my streamline of a lid driven cavity by comparing your solution with mine. In addition, your solution was accepted by the international journal which i can rely on. thanks for your help. Would you mind send the FE code to me? my email is as shown above
Thank you very very much
Old   August 26, 2009, 13:02
Idris,
I will send the Matlab LDC code for one of the methods to you as attachments. A preprint of the paper describing the method can be found at http://webpages.charter.net/jtholdeman/RevIJNMFart1.pdf .
Old   September 2, 2009, 04:30
thanx guys,
i finally created the code myself. it's the matter of boundary condition.
if the boundary condition is wrong, the solution also wrong. Actually my task is to solve vorticity-streamfunction equation of a lid driven cavity at steady state(using central finite difference). and not to forget,the relaxation scheme is needed when the reynolds number is very high (Re >1000)
Anyway, many thanks to everybody, especially Jonas Holdeman.
bye.
Old   October 8, 2009, 06:16
bhagat is on a distinguished road
can u please share the code....
thank you.
bhagat is offline   Reply With Quote
Old   October 8, 2009, 23:28
ok, here it is
clear all;clf;clc;
re=100; % for higher reynolds number(>500-1000), use under relaxation
rex=1; % underrelaxation, 0<rex<1
rexb=rex;
nx=51; dx=1/(nx-1); %100x100 grid (101*101 nodes)
ny=51; dy=1/(ny-1);
fac=2*(1/dx^2+1/dy^2);
Y=1;
uo=1;
nu=Y/(uo*re);
% initial condition
p(1:nx,1:ny)=0;
o(1:nx,1:ny)=0;
psi(1:nx,1:ny)=0;
omega(1:nx,1:ny)=0;
uact(1:nx,1:ny)=0;
vact(1:nx,1:ny)=0;
u(1:nx,1:ny)=0;
v(1:nx,1:ny)=0;
u(1:nx,ny)=1;
for iteration =1:2000%iteration
disp(['iteration= ',int2str(iteration)])
% stream function(internal nodes)
for i=2nx-1)
for j=2ny-1)
pold(i,j)=p(i,j);
f1=1/fac*(o(i,j)+(p(i+1,j)+p(i-1,j))/dx^2+(p(i,j+1) ...
+p(i,j-1))/dy^2);
p(i,j)=p(i,j)+rex*(f1-p(i,j));
end
end
% Vorticity (Boundary nodes)
for j=1:ny
fab=-2*p(2,j)/dx^2; %left side(AB)
o(1,j)=o(1,j)+rexb*(fab-o(1,j));
fcd=-2*p(nx-1,j)/dx^2; %right side(CD)
o(nx,j)=o(nx,j)+rexb*(fcd-o(nx,j));
end
for i=1:nx
fad=-2*p(i,2)/dy^2; %bottom side(AD)
o(i,1)=o(i,1)+rexb*(fad-o(i,1));
fbc=-(2*p(i,ny-1)+2*uo*dy)/dy^2; %top side (BC)
o(i,ny)=o(i,ny)+rexb*(fbc-o(i,ny));
end
%vorticity internal nodes
for i=2nx-1)
for j=2ny-1)
oold(i,j)=o(i,j);
f2=1/fac*((o(i+1,j)+o(i-1,j))/dx^2+(o(i,j+1)+o(i,j-1))/dy^2 ...
-re*(p(i,j+1)-p(i,j-1))*(o(i+1,j)-o(i-1,j))/(4*dx*dy)...
+re*(p(i+1,j)-p(i-1,j))*(o(i,j+1)-o(i,j-1))/(4*dx*dy));
o(i,j)=o(i,j)+rex*(f2-o(i,j));
end
end
% Calculate the velocity (u and v)
for i=2nx-1)
for j=2ny-1)
u(i,j)=(p(i,j+1)-p(i,j-1))/(2*dy);
v(i,j)=-(p(i+1,j)-p(i-1,j))/(2*dx);
end
end
% rearrange in cartesian coordinate
%(which originally in matrix coordinate)
for i=1:nx
for j=1:ny
k=i;
l=j;
psi(l,k)=p(i,j);
omega(l,k)=o(i,j);
uact(l,k)=u(i,j);
vact(l,k)=v(i,j);
end
end
figure(1)% Streamline plot with number
Z = psi(1:ny,1:nx);
X = linspace(0,1,size(Z,2));
Y = linspace(0,1,size(Z,1));
[c,h] = contour(X,Y,Z);
axis equal
axis([0 1 0 1])
drawnow
end
hope you can further developed these code by yourself. It's up to you what you are going to do about it :-)
metmet, ananthulasriram and rcp like this.
Old   October 9, 2009, 04:45
thank you very much
Old   November 13, 2010, 04:55
KHB
lava12005 is on a distinguished road
Hi guys, I am a newbie in CFD thing. Currently I am trying to solve the same problem also.
I solved the problem using the stream function formulation, and now I'm trying to solve in in terms of primitive variable (u,v, and p) using projection method.
First I tried using the most simple explicit projection method and it turns out the solution diverge, and I also used implicit projection method where the value of velocity field in each time step is iterated first and it still diverge. I don't know whats wrong with the code.. Have any of you tried to solve the problem using Projection method?
lava12005 is offline   Reply With Quote
Old   November 15, 2010, 14:29
Marshall Ericson
Marshall is on a distinguished road
thank you very much for posting these codes. but these codes seem to have some problems. it doesnt give correct plot nor correct data. if you have any other simple matlab code for lid driven cavity problem that worked , i would be very grateful.
Marshall is offline   Reply With Quote
Old   November 16, 2010, 12:05
Tanay Deshpande
Tanay is on a distinguished road
Hello All,
I'm trying to implement SIMPLE in Finite Volume method in driven-cavity flow using C++ in basic variables. Since the problem is steady state, I start out with u=0, v=0, p=0 for all interior nodes. This is causing the code to diverge away to infinity. For high viscosities, the divergence is less pronounced but u doesn't ever become negative in the results as it should. What may be the problem? Is it because I'm using unrelaxed pressure and velocity corrector equations?
Thanks in advance.
Tanay is offline   Reply With Quote
Old   May 15, 2011, 10:56
Default lid driven Cavity using FVM
  #16
ainal
ainal is on a distinguished road
hello ,
I am working on a CFD problem and developing a Matlab code for "Lid driven cavity " problem using finite volume method and Symmetric Couple Gauss Seidel Scheme but i have some confusion in writing the code in Matlab so can any one help me in this ...
I shall be very grateful if anyone can share this
ainal is offline   Reply With Quote
Old   April 15, 2013, 00:15
TAMILNADU
ananthulasriram is on a distinguished road
bro do u have any unsteady code for the same problem.. ??
ananthulasriram is offline   Reply With Quote
Old   April 14, 2014, 06:23
Default Lid Driven Cavity using Staggered grid
  #18
sankha
fireblade is on a distinguished road
i have done LDC in collocated grid in stream function vorticity method...right now trying to do it in staggered grid in primitive variable method FDM....can somebody send me the code so that i can verify my results.. sm4fn@hotmail.com
i'm using SIMPLE
fireblade is offline   Reply With Quote
Old   July 21, 2014, 10:29
Bob Man
Boobale is on a distinguished road
Originally Posted by idris View Post
ok, here it is
clear all;clf;clc;
rexb=rex;
ny=51; dy=1/(ny-1);
Y=1;
uo=1;
nu=Y/(uo*re);
% initial condition
p(1:nx,1:ny)=0;
o(1:nx,1:ny)=0;
psi(1:nx,1:ny)=0;
omega(1:nx,1:ny)=0;
uact(1:nx,1:ny)=0;
vact(1:nx,1:ny)=0;
u(1:nx,1:ny)=0;
v(1:nx,1:ny)=0;
u(1:nx,ny)=1;
for i=2nx-1)
for j=2ny-1)
pold(i,j)=p(i,j);
+p(i,j-1))/dy^2);
end
end
for j=1:ny
end
for i=1:nx
end
for i=2nx-1)
for j=2ny-1)
oold(i,j)=o(i,j);
end
end
for i=2nx-1)
for j=2ny-1)
end
end
for i=1:nx
for j=1:ny
k=i;
l=j;
psi(l,k)=p(i,j);
omega(l,k)=o(i,j);
uact(l,k)=u(i,j);
vact(l,k)=v(i,j);
end
end
Z = psi(1:ny,1:nx);
axis equal
axis([0 1 0 1])
drawnow
end
Can anyone explain why the boundary conditions for the vorticity are what they are? I mean what kind of approximation is that for the derivative of psi?
Also what scheme is used for calculating the internal nodes of the vorticity?
Thanks alot for the help
Boobale is offline   Reply With Quote
Old   January 9, 2017, 04:09
Sumaira Mehmood
Sumaira Mehmood is on a distinguished road
hi, guys
i need help how to find skin friction in 2-dimensional flow in lid driven cavity in matlab code kindly tell me its matlab command. i have already done but not get results.
its my email address Sumaira_61554@yahoo.com
Sumaira Mehmood is offline   Reply With Quote
2D Lid Driven Cavity Flow simulation using MATLAB josephlm Main CFD Forum 4 August 17, 2023 20:36
Lid Driven Cavity using Ghost Cell Method and in C++ illuminati5288 Main CFD Forum 0 August 12, 2011 22:05
finite volume method - lid driven cavity ainal Main CFD Forum 0 May 15, 2011 11:06
is there any parallel code for the famous Lid Driven Cavity flow? gholamghar Main CFD Forum 0 August 1, 2010 01:55
Lid driven cavity flow KK FLUENT 1 December 16, 2009 18:10
