January 10, 2017, 05:27 |
mass flow rate
i am getting negative mass flow rate at outlet of my flow domain. what does that mean ?
January 10, 2017, 05:47 |
Alex
Rep Power: 46 |
Summoning all my psychic power I sense that this is a Fluent or CFX question despite the hint "do not post fluent questions here".
In this case, a negative mass flow rate indicates that flow velocity vector and surface normal vector are pointing in opposite directions. In these programs, surface normal vectors point towards the computational domain by default. |
Higher mass flow rate at outlets as compare to inlet | Ahmed Saieed | FLUENT | 0 | April 3, 2016 23:08 |
trying to perform accurate mass flow rate sampling through hot-film probe | UTA_ARC | ANSYS | 0 | December 2, 2015 13:20 |
Calculating mass flow rate at multiphase flows | Kuslo187 | OpenFOAM Post-Processing | 1 | August 21, 2015 18:11 |
mass flow rate in DPM steady tracking | Roule | FLUENT | 4 | June 1, 2015 10:44 |
mass flow rate error | Masood | FLUENT | 0 | May 22, 2005 00:32 |
