January 13, 2017, 06:53 |
cavity problem
Rep Power: 9 |
hello my friends , i have an urgent task in cfd course ,i put the image of problem here,i want the codes and approach of solving
thank you11111111111111111.JPG |
January 13, 2017, 09:34 |
Jonas T. Holdeman, Jr.
Rep Power: 18 |
If you have Matlab, go to the top of this page and select wiki -> source code archive -> educational and select one of the 2D lid-driven cavity codes. Change a few lines in the essential boundary conditions section of the program script and, apart from some cosmetic changes to the output, it should give your answer.
Your instructor assigned this so you could learn something. The answer is not as important as what you learn from it. |
January 14, 2017, 12:19 |
Rep Power: 9 |
thank you for your answer and your guidance,i always do my task .
have great moment. |
The Upper Limit of Relaxation Parameter for Lid-Driven Square Cavity Problem wtih SOR | Ilker | Main CFD Forum | 0 | January 5, 2013 10:56 |
Cavity problem in matlab | rezahemmat1985 | Main CFD Forum | 0 | February 13, 2012 06:11 |
Problem OpenFOAM/Paraview (cavity tutorial) | vianne | OpenFOAM | 8 | February 20, 2010 06:52 |
Problem with increasing Re no. for cavity flow | Quarkz | Main CFD Forum | 3 | July 2, 2005 16:58 |
CODE FOR THE CAVITY FLOW PROBLEM | ricky | Main CFD Forum | 1 | November 8, 2001 11:21 |
