January 26, 2017, 15:35 |
Finite volume discretization
Miad Al Mursaline
Rep Power: 9 |
Is there any paper or book where I can find finite volume discretization of general unsteady transport equation in collocated body fitted grids? I have found a paper where the steady case is discussed.Since I am a novice in cfd,without a good paper or book I cannot proceed alone.
January 27, 2017, 03:05 |
Filippo Maria Denaro
Rep Power: 71 |
in which CFD books have you searched the topic so far?
January 27, 2017, 10:29 |
Miad Al Mursaline
Rep Power: 9 |
Thank you for the reply.I have seen the topic in a paper(Numerical Study of the Turbulent Flow
Past an Airfoil with Trailing Edge SeparationC. M. Rhie)but have not found it in any textbook. I have seen Intro to CFD by Malalasekera and book of Ferziger and Peric.But I have not found any source where unsteady FVM discritization in body fitted grids is discussed.In the textbook for Malalasekera the discritization for cartesian grids is discussed.Although the transformation is not complicated but tedious.I have tried to do it,but I am not sure whether my derived algebraic equation is correct. |
January 27, 2017, 11:27 |
Rep Power: 71 |
Actually, I am not sure of what you are looking for...
Unlike finite difference, finite volume allows you to compute directly the discrete flux on several types of grids without a coordinates transformation. The book of Peric and Ferziger explains that. Once computed the fluxes, you can compute an update with some time integration method. However, if you found a paper for the steady case, you can use that method for the computation of the integral of the fluxes and then use such terms in a semi-discretized time integration |
January 27, 2017, 12:45 |
#5 | |
Miad Al Mursaline
Rep Power: 9 |
January 27, 2017, 12:49 |
Rep Power: 71 |
yes, of course ...depending on the discretization, they change also on a uniform structured grid.
I suggest to start with simple problems to understanding the implementation |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
finite volume discretization | sciense | Main CFD Forum | 11 | August 26, 2014 05:04 |
k-e turbulace model finite volume discretization | sciense | Main CFD Forum | 1 | June 13, 2014 08:29 |
influence of convex or concave control volume in finite volume discretization | openfoammaofnepo | Main CFD Forum | 1 | March 24, 2014 02:13 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
