Reg: Buoyant flow in partitioned Cavity
Old   February 1, 2017, 03:28
Smile Reg: Buoyant flow in partitioned Cavity
CFD Engineer is on a distinguished road
Dear Freinds,
I am working on a tutorial "Buoyant flow in partitioned Cavity " in CFX. i fund the gravity is given in X and Y to compensate the need to tilt the plate by 30 degree. I am confuse how the values -4.9 and -8.5 m/s2 came in the X and Y direction respectively. I know the sine and cosine rule but confused in this particular case. An image of geometry is attached below.
Thank You
CFD Engineer is offline   Reply With Quote
Old   February 1, 2017, 03:49
Hector Redal
HectorRedal is on a distinguished road
Originally Posted by CFD Engineer View Post
Dear Freinds,
Thank You
Attachment 53696
I have performed the following calculations:
- 4.9 and 8.5 are the componentes of the gravity vector with module 9.81 = sqrt(4.9^2 and 8.5^2) = 9.81 (as expected)
- acos(4.9/9.81) = 60º which is the complementary angle of 30, based on the reference system.
- asin(8.5/9.81) = 60º which is the complementary angle of 30, based on the reference system.
From my point of view all is correct.
HectorRedal is offline   Reply With Quote
Flow over a cavity inconsistent Sparow89 FLUENT 0 June 20, 2016 12:02
Oscillating flow over a cavity validation case Sparow89 FLUENT 0 June 2, 2016 15:18
Lid driven cavity flow KK FLUENT 1 December 16, 2009 18:10
Reg Mass flow rate jksanil CFX 1 January 6, 2009 03:08
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
