February 1, 2017, 03:28 |
Reg: Buoyant flow in partitioned Cavity
Rep Power: 11 |
Dear Freinds,
I am working on a tutorial "Buoyant flow in partitioned Cavity " in CFX. i fund the gravity is given in X and Y to compensate the need to tilt the plate by 30 degree. I am confuse how the values -4.9 and -8.5 m/s2 came in the X and Y direction respectively. I know the sine and cosine rule but confused in this particular case. An image of geometry is attached below. Thank You cfd.PNG |
February 1, 2017, 03:49 |
#2 | |
Hector Redal
- 4.9 and 8.5 are the componentes of the gravity vector with module 9.81 = sqrt(4.9^2 and 8.5^2) = 9.81 (as expected) - acos(4.9/9.81) = 60º which is the complementary angle of 30, based on the reference system. - asin(8.5/9.81) = 60º which is the complementary angle of 30, based on the reference system. From my point of view all is correct. |
Flow over a cavity inconsistent | Sparow89 | FLUENT | 0 | June 20, 2016 12:02 |
Oscillating flow over a cavity validation case | Sparow89 | FLUENT | 0 | June 2, 2016 15:18 |
Lid driven cavity flow | KK | FLUENT | 1 | December 16, 2009 18:10 |
Reg Mass flow rate | jksanil | CFX | 1 | January 6, 2009 03:08 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
