Although having reduced the time step, the simulation is not converging |
February 1, 2017, 03:37 |
Hector Redal
I am trying to perform an analysis of the convergence when reducing the grid of an algorithm that I have implemented. The problem I am simulating is a flow past a circular cylinder. I am using several meshes: (1) Coarse Grid -> 2546 nodes, 4918 tria elements (2) Medium Grid -> 7294 nodes, 14334 tria elements (3) Fine Grid -> 19716 nodes, 38887 tria elements (4) Very Fine Grid -> 84442 nodes, 167973 tria elements. All works fine for the (1), (2) and (3) grids. And I have managed to get a solution quite close to the expected solutions appearing in refernces with an error less than 2% in all the three grids. But when trying to simulate the flow using the (4) grid, after a few steps (50 - 60 time steps approximately) of the transiente simulation, the velocity field grows very much, and the solutions starts to diverge. I have reduced the time step a lot, but there has been no improvement. Indeed, if I reduced the time step even more (1e-7), the solution diverges even earlier. I have tried with big time steps and with small time steps, but I have not found a way to get the algorithm work. I have tried to use even a very small value for the tolerance of the matrix inverse calculation (1e-20), but there has been no improvement. Any suggestion on why this is not working? Best regards, Hector. |
February 1, 2017, 03:56 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
It seems a numerical instability issue but I want ask you if the solution definitely blow-up or simply starts to oscillate. Plot the total kinetic energy versus time. The reduced time step should drive into a stability region and if this does not happen you could have a bug in your code. Are you sure that changing the grid resolution no others setting are changed? Are you sure that the problem is not in the generated triangle in grid 4) ?? |
February 1, 2017, 09:02 |
#3 | |
Hector Redal
I'm afraid there is some bug in the code, because when chaninge the grid resolution, other setting are not changed (keeping non-dimensional parameter constant). I can try to generate another grid, so as to avoid any problem in the grid. That is also one of my concerns, that there is an error in the grid or in the boundary conditions placed in the nodes of the grid. The point is that, the more number of nodes, the much probability exist to make an error when setting boundary conditions. |
February 1, 2017, 21:29 |
#4 | |
Arjun
Rep Power: 34 |
it is possibly not a bug but we don't know good solution. There is a similar thread here too Time convergence study problems, very small time steps Unfortunately there is nothing a user can do to fix it. I have faced a similar problem during VOF calculations where reduction in time step finally blows solution out rather than helping to converge. |
February 2, 2017, 03:37 |
#5 | |
Rep Power: 71 |
If I understand correctly the original question, here the problem is different, the solution blow-up on the grid (4), the finest grid, for every value of the time-step, not just for small values. |
February 3, 2017, 11:20 |
#6 | |
Hector Redal
The solution blows up only in grid (4), the finest one. In any other grid, the solution works fine. I am going to generate another grid and check if the algorithm works in this new grid. A grid intermediate betwen (4) and (3). |
February 4, 2017, 06:59 |
Hector Redal
When solving the system A x = b, I am using a tolerance of 1e-10. I don't know if this tolerance is too high. And this is what is causing the algorithm to blow up.
Do you think it's better to use for example tol=1e-20, when the number or nodes increases a lot? The problem then is that the solution time is going to grow exponentially, I am afraid. |
February 4, 2017, 08:12 |
#8 | |
Rep Power: 71 |
If you are using non dimensional form of the equations, a tolerance of 10^-8 should be sufficient. Differently, you should normalize the residual by its value at the zero-th iteration. |
February 4, 2017, 08:42 |
Arjun
Rep Power: 34 |
February 4, 2017, 08:46 |
#10 | |
Arjun
Rep Power: 34 |
All depends on what is flow solver algorithm. Are you solving with pressure projection method then yes, it seems that needs much lower tolerance. If you are solving with pressure correction algorithm then no, 1E-10 is actually extra low in my opinion. (I have had run 3 billion cell calculations where i did not converge linear system more than 1E-4 tolerance). Usually finer the mesh more stable it is so i would try to find out the skew in this mesh because it seems there might be one or two elements that are making it blow up (1 bad element is enough actually). |
February 4, 2017, 09:29 |
#11 | |
Hector Redal
Accordingto my knowledge, the tolerance is for the norm of |Ax-b|/|b|. I am trying to solve it using a 10^-20 tolerance. |
February 4, 2017, 09:31 |
#12 | |
Hector Redal
The mesh I am using has 160.000 tria elements, that is definitely a corarser mesh than the one you tested. If I were able to solve it... |
February 4, 2017, 09:42 |
#13 |
Hector Redal
How can I detect skew cells?
February 4, 2017, 12:25 |
#14 |
Rep Power: 71 |
February 5, 2017, 04:42 |
#15 |
Hector Redal
That is the tolerance that I have using before calling the solve method in the Eigen library (1e-20).
So far, I have not received any kind of notification / error from the method solve() stating that this tolerance has not been reached. So, I understand that in somehow it is the expected error after receiving the solution. By the way, I have managed to make the simulation run. I have increased the delta t (time step), and now the simulation does not blow up. Before I was trying out these time steps: delta t = 1e-5 delta t = 1e-6 delta t = 1e-7 The simulation does not work with any of that values of time step. After a couple of iterations (of time), more or les 30-40, the simulation blew up. Now, I am running the simulation using delta t= 1e-4, at it appears it works. I have performed more than 10000 iterations, and the simulation has not blown up yet. Using a delta t=1e-3, the simulation blows up, since the time step is greater than the Courant number. So, I'm afraid the problem is related to previously problem indicated by arjun (Time convergence study problems, very small time steps) |
February 5, 2017, 06:24 |
#16 |
Rep Power: 71 |
Hector, from my experience I would still think about a bug in the code and the only way to assess that is by performing the check of the accuracy slope on an analytical test-case by taking constant the ratio dt/h. This is mandatory...
What about your time and space discretization? In the test you will discover if the accuracy slope corresponds to the theoretical one for yout method. If the slope deviates you can be sure of a bug. From a more general framework, the local truncation error (LTE) is a function of h and dt. When you fix h (that means working one grid) a part of the LTE remains constant while the dt is diminuished. At a certain small value dt, the part of the LTE that depends only on dt can be disregarded and you see only the effect of the spatial discretization even for smaller time-step. A blow-up would mean that this remaing part causes a negative numerical diffusion. I am not aware of schemes having such behaviour ... |
February 5, 2017, 11:20 |
#17 |
I faced the same issue, but my problem was different. Indeed my solution blew up if my dx was diminished. I haven't found the reason yet. I will recommend you to interpolate the fine solution to the finest solution. You did not mentioned anything about the model you are using: les or unresolved dns. I have seen that at some point you start capturing more relegant physical structures that need to be damped. Once I read that this was common for the vortex name street phenomenon. In commercial softwares and meshers you can medio distorting the mesh. Check for skeness.
February 6, 2017, 04:52 |
#18 |
Arjun
Rep Power: 34 |
Now if you are able to get it to run with higher time step size then understand that your solution now is more smooth or diffusive.
At this moment it is hard to know if it is due to bug or it is supposed to behave this way. Anyway, now I would suggest that run the same calculation with first order upwind then then reduce the timestep. Since upwind scheme also has diffusive nature or error, it shall be stable again and allow you smaller time step. Also can I ask, what solver we are talking about. Is it one of the commercial code? |
February 6, 2017, 04:59 |
#19 |
Rep Power: 71 |
All those suggestions are right, however, I STRONGLY suggest to use an analytical test-case (e.g. Taylor solution) and performing the refinement study. This is the ONLY way to assess the presence of a bug.
February 6, 2017, 06:33 |
#20 | |
Hector Redal
First of all, I would like to thank you for your help and support on this issue. I totally agree with you on your comments and suggestions. The test you have commented about estimating the acurary slope is something I did a couple of months ago. The estimated error slope was approximately 2, which matches the second order error of the Characteristics Based Split Algorithm (according to the authors Zienkiewicz et al). You couldn't have explained it better. Since the code I have developed is the implementation of the Taylor series expansion of two variables (time discretization and space discretization), if one of the delta tends to zero, then the remaining error (when comparing with the theorethical function) is only caused by the approximation caused by the other variable. The point with your reasoning that I do not fully agree with is the one stating that the problem is related to diffusion (artificial viscosity). Maybe the error is not in the calculation of the viscotity term of the algorithm but in any other term. Something that I have to investigate. The point is that I am facing this problem more than one year and it is still unsolved. I am not very confident I will be able to find it either. |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 07:09 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
time step directories naming issue | Andrea_85 | OpenFOAM | 3 | April 3, 2014 08:38 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
