Natural convection in enclosure with heat generating source |
February 2, 2017, 03:03 |
Swapnil P
Rep Power: 10 |
Facing big confusion regarding understanding of the flow in enclosure with heat generating strip at the middle.
The strip is placed in the middle of the square enclosure and generating uniform heat. The top and bottom walls are adiabatic and vertical side walls are isothermal at ambient temperature. The temperature profile and velocity profile is similar on both side of the strip but how come the intensity of the contours (stream function) is different on both sides of strip? For reference providing the stream function, isotherms and velocity magnitude profile. |
February 2, 2017, 03:34 |
Filippo Maria Denaro
Rep Power: 71 |
The solution seems reasonable, is steady (very low Re number?) and symmetric, the temperature field show a stratification. What is strange is that you do not have zero velocity at walls
February 2, 2017, 03:43 |
Swapnil P
Rep Power: 10 |
Yes its steady state natural convection problem with high Rayleigh number 10^9. Also, the amount of heat generation is very low as compare to the length of the geometry.
February 2, 2017, 03:55 |
Rep Power: 71 |
February 2, 2017, 04:10 |
Swapnil P
Rep Power: 10 |
February 2, 2017, 04:26 |
Rep Power: 71 |
Ok, then I don't see problems in the solution...just consider to do the grid refinement study to assess convergence of the solution
February 2, 2017, 05:36 |
Swapnil P
Rep Power: 10 |
Actually, there is no problem in the solution but the understanding of the stream function in the enclosure, which is not uniform inside the enclosure. If you check the stream function contours, it is more intense on one side of the heat generating strip as compare to other side. How come this is possible?
February 2, 2017, 05:44 |
Rep Power: 71 |
could you plot the contour lines instead of the shaded contour? I suggest to superimpose the streamline contours to the vector plot....when two streamlines are close, the velocity is greater than when they are more far..
ansys fluent, fluid flow, heat transfer, natural convection, stream function |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
Natural convection in oil filled enclosure | abu250feldman | FloEFD, FloWorks & FloTHERM | 5 | December 4, 2013 09:37 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
Natural Convection with heat generation | krishnachandranr | Main CFD Forum | 0 | July 28, 2009 04:22 |
