NASA Polynomials >> UNITS <<
Like Tree2Likes
  • 2 Post By wangmianzhi
Old   June 13, 2015, 11:09
Default NASA Polynomials >> UNITS <<
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
I am a bit confused about the NASA Polynomials and the units they have. I am right with the following stuff:
  • cp -> kJ/molK
  • H -> kJ/mol
  • S -> kJ/molK
or is it kcal/mol or only J/mol? Thanks in advance.
PS: I think it depend on the unit of the individuel gas constant R. If I use it in J/molK the units should be like that.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   June 13, 2015, 14:12
Mianzhi Wang
wangmianzhi is on a distinguished road
I think you are right about the R.
If I remember correctely, they are dimensionless, e.g. h/RT, s/R, cp/R.
wangmianzhi is offline   Reply With Quote
Old   June 14, 2015, 19:35
Jenna
jennap223 is on a distinguished road
I believe you are correct in treating it that way. That is how I have done it, using R =8.314 J/mol-K to get Cp in those same units and dividing by the molar mass such that it is J/kg-K
A good sources for NASA Polynomial explanation is:
http://combustion.berkeley.edu/gri_m...nasa_plnm.html
and a list of polynomials themselves
https://combustion.llnl.gov/content/...anes_therm.txt
jennap223 is offline   Reply With Quote
Old   June 15, 2015, 02:45
Tobi's Avatar
Tobias Holzmann
Dear all,
thanks for the replays and the feedback. The sites of grimech and the nasa polynomials I know
Thus you showed the NASA site, can you just clear my mind about that line:
 H in the above equation is defined as
    H(T) = Delta Hf(298) + [ H(T) - H(298) ]  so that, in general, H(T) is not equal to Delta Hf(T) and one needs to have the data for the reference elements to calculate Delta Hf(T).
Till now I did not get the point of the defintion of H
For example: If I calculate H at 298 I get H(298) = deltaHf
Keep foaming,
Tobias Holzmann
Old   June 15, 2015, 10:14
Mianzhi Wang
It means if you want Delta Hf(500) of water, You'll need not only H(T) of water, but also H(T) of H2 and O2 as well.
The fact that Delta Hf(298) = H(298) for any species is because H(298) = 0 for any species like H2, O2 (the most stable single-element species at reference state).
Originally Posted by Tobi View Post
Dear all,
Old   January 22, 2016, 18:37
Tobi's Avatar
Tobias Holzmann
Hello Wang,
I have a question for the deltaH calculation. If I made some comparison I always have problems with deltaH (I did not get the point). For example we can check some data here:
http://combustion.berkeley.edu/gri-m...cies/c3h8.html
If I calculate cp(T), S(T) and "H(T)" I get this one:
T: 200, 11.6896  58.7521  -26285.9
T: 300, 17.4924  64.6154  -24820.2
T: 400, 22.5544  70.3576  -22812.1
T: 500, 26.9572  75.8749  -20331.3
T: 600, 30.7775  81.1358  -17440.1
T: 700, 34.0862  86.1348  -14192.9
T: 800, 36.9492  90.8779  -10637.7
T: 900, 39.4266  95.3764  -6815.89
T: 1000, 41.5734  99.6442  -2763.35
T: 1100, 43.4391  103.696  1489.42
T: 1200, 45.0678  107.547  5916.56
T: 1300, 46.4983  111.212  10496.4
T: 1400, 47.7639  114.705  15210.7
T: 1500, 48.8926  118.04  20044.6
T: 1600, 49.907  121.228  24985.4
T: 1700, 50.8242  124.282  30022.8
T: 1800, 51.6561  127.211  35147.4
T: 1900, 52.4093  130.024  40351.4
T: 2000, 53.0877  132.73  45626.8
T: 2100, 53.6953  135.335  50966.5
T: 2200, 54.236  137.846  56363.6
T: 2300, 54.714  140.268  61811.6
T: 2400, 55.1335  142.605  67304.5
T: 2500, 55.4988  144.863  72836.5
T: 2600, 55.8144  147.046  78402.6
T: 2700, 56.0847  149.158  83997.9
T: 2800, 56.3145  151.202  89618.2
T: 2900, 56.5086  153.182  95259.6
T: 3000, 56.6718  155.1  100919
T: 3100, 56.8092  156.961  106593
T: 3200, 56.9258  158.766  112280
It can be seen that cp and S are very nice but for deltaH its total bad. I know why, because I calculate H and not deltaH. But I still do not get the point how to calculate deltaH.
Keep foaming,
Tobias Holzmann
Old   January 23, 2016, 00:04
Mianzhi Wang
Hello Wang,
The subscript "f" in the "Delta h_f" means formation from the most stable single-element specie (i.e. 3*C and 4*H2 for propane).
In this case:
Delta h_f (T)_propane = h(T)_propane - 3h(T)_C -4h(T)_H2
Tobi and Saifullah like this.
Old   January 23, 2016, 04:23
Tobi's Avatar
Tobias Holzmann
Thank you very much.
Now I got it (:
Keep foaming,
Tobias Holzmann
Old   January 23, 2016, 06:03
Tobi's Avatar
Tobias Holzmann
Just to get it 100% clear:
h_f(T)_C2H3CHO = h(T)_C2H3CHO -  2h(T)_C - 4h(T)_H2 - h(T)_O
or would be O -> 1/2 O2 as:
h_f(T)_C2H3CHO = h(T)_C2H3CHO -  2h(T)_C - 4h(T)_H2 - 0.5h(T)_O2
Or another example for butyl (C4H9):
Delta h_f (T)_butyl = h(T)_butyl - 4h(T)_C -4.5h(T)_H2
As far as I understand you:
its always H2, O2, C, N2, HE and never H, O, C2, N...
I am right?
Keep foaming,
Tobias Holzmann
Old   January 23, 2016, 18:59
Tobi's Avatar
Tobias Holzmann
Hey,
today I investigated into that problem again and with your statement I figured it out but I have still a problem. For example my calculated results are similar to that one postulated in the above link. I pointed out that its is like that:
Hf(NO2) = H(NO2) - H(O2)
Hf(OH) = H(OH) - 0.5 H(O2) - 0.5 H(H2)
Hf(O2) = H(O2) - H(O2) = 0  (also for N2, H2, AR)
Here one example: NNH
Hf(NNH) = H(NNH) - H(N2) - 0.5 H(H2)
b) T = 200 :::: dHf(NNH) = 59.8241
b) T = 300 :::: dHf(NNH) = 59.6058
b) T = 400 :::: dHf(NNH) = 59.4136
b) T = 500 :::: dHf(NNH) = 59.2674
b) T = 600 :::: dHf(NNH) = 59.1694
b) T = 700 :::: dHf(NNH) = 59.1105
b) T = 800 :::: dHf(NNH) = 59.0774
b) T = 900 :::: dHf(NNH) = 59.0592
b) T = 1000 :::: dHf(NNH) = 59.0538
b) T = 1100 :::: dHf(NNH) = 59.0617
b) T = 1200 :::: dHf(NNH) = 59.0763
b) T = 1300 :::: dHf(NNH) = 59.0964
b) T = 1400 :::: dHf(NNH) = 59.1212
b) T = 1500 :::: dHf(NNH) = 59.1495
b) T = 1600 :::: dHf(NNH) = 59.1806
b) T = 1700 :::: dHf(NNH) = 59.2138
b) T = 1800 :::: dHf(NNH) = 59.2485
b) T = 1900 :::: dHf(NNH) = 59.2839
b) T = 2000 :::: dHf(NNH) = 59.3198
b) T = 2100 :::: dHf(NNH) = 59.3555
b) T = 2200 :::: dHf(NNH) = 59.3909
b) T = 2300 :::: dHf(NNH) = 59.4254
b) T = 2400 :::: dHf(NNH) = 59.459
b) T = 2500 :::: dHf(NNH) = 59.4913
b) T = 2600 :::: dHf(NNH) = 59.5222
b) T = 2700 :::: dHf(NNH) = 59.5514
b) T = 2800 :::: dHf(NNH) = 59.579
b) T = 2900 :::: dHf(NNH) = 59.6046
b) T = 3000 :::: dHf(NNH) = 59.6283
ALso with H20, NO2 and so forth the results are excellent. But if I take a species where "C" is included it is not working anymore. This can not be correct:
Hf(C3H8) = H(C3H8) - 3*H(C) - 4*H(H2)
because if I calculate Hf(C) it is H(C)
Hf(C) = H(C)
If we compare this one http://combustion.berkeley.edu/gri-m...ecies/ch3.html with my calculated one:
b) T = 200 :::: dHf(CH3) = 35.2246
b) T = 300 :::: dHf(CH3) = 35.0925
b) T = 400 :::: dHf(CH3) = 35.0072
b) T = 500 :::: dHf(CH3) = 34.9932
b) T = 600 :::: dHf(CH3) = 35.057
b) T = 700 :::: dHf(CH3) = 35.193
b) T = 800 :::: dHf(CH3) = 35.3905
b) T = 900 :::: dHf(CH3) = 35.6399
b) T = 1000 :::: dHf(CH3) = 35.9392
b) T = 1100 :::: dHf(CH3) = 36.2862
b) T = 1200 :::: dHf(CH3) = 36.6695
b) T = 1300 :::: dHf(CH3) = 37.0838
b) T = 1400 :::: dHf(CH3) = 37.5241
b) T = 1500 :::: dHf(CH3) = 37.9862
b) T = 1600 :::: dHf(CH3) = 38.4664
b) T = 1700 :::: dHf(CH3) = 38.9615
b) T = 1800 :::: dHf(CH3) = 39.4685
b) T = 1900 :::: dHf(CH3) = 39.9851
b) T = 2000 :::: dHf(CH3) = 40.5092
b) T = 2100 :::: dHf(CH3) = 41.0392
b) T = 2200 :::: dHf(CH3) = 41.5736
b) T = 2300 :::: dHf(CH3) = 42.1113
b) T = 2400 :::: dHf(CH3) = 42.6515
b) T = 2500 :::: dHf(CH3) = 43.1932
b) T = 2600 :::: dHf(CH3) = 43.7361
b) T = 2700 :::: dHf(CH3) = 44.2796
b) T = 2800 :::: dHf(CH3) = 44.8234
b) T = 2900 :::: dHf(CH3) = 45.3671
b) T = 3000 :::: dHf(CH3) = 45.9105
There is something wrong. Its with each species where "C" is included. I use exact the same NASA Polynomials. It would be very nice if you could clear my doubts.
Kind regards,
Tobi
Keep foaming,
Tobias Holzmann
Old   January 23, 2016, 19:14
Tobi's Avatar
Tobias Holzmann
It is already late but I think I am wrong in one case:
Hf(CH3) = H(CH3) - H(C)_solid - 1.5 * H(H2)
I will check it out because in other NASA Polynomials I found that I have two entrys for C. One for the gas and one for solid. I think H(C) is always solid state due to the fact of stable phase.
Keep foaming,
Tobias Holzmann
Old   February 23, 2017, 13:47
Abdul Rehman Bangash
AR Bangash is on a distinguished road
Hi Tobi,
Would you share how did you solve the problem with carbon?
Regards
AR Bangash is offline   Reply With Quote
Thermophysical Property Units johanz OpenFOAM Pre-Processing 2 December 16, 2018 10:08
therm.dat NASA polynomials mystix OpenFOAM 5 May 31, 2018 03:17
nasa polynomials gardian CFX 3 March 10, 2011 06:29
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 16:55
NASA polynomials, thermo.dat tables Tomislav Sencic Main CFD Forum 8 December 15, 2009 10:09
