March 8, 2017, 07:22 |
Help in FORTRAN PROGRAMMING
Karan Gupta
Rep Power: 9 |
Respected members
While writing a fortran subroutine I am using this statement write(UNIT=10000+myrank) tamp_mat(1:endx,1:endy, nn_loc) and on running the code the error comes Segmentation fault - invalid memory reference this nn_loc represents the time step and this subroutine is called at each and every time step. and the same variable is mentioned elsewhere in a subroutine from which it writes the values there it is given as tamp_mat(i,j,nn_loc)=tmp_mat(i,j) in this nn_loc varies from 3: endt-1 Please help me to find out the cause of error. your sincerely Karan Gupta |
March 8, 2017, 07:33 |
Alex
Rep Power: 46 |
Use debugging flags to compile your code. At least -traceback -check bounds
edit: or -fbounds-check -fbacktrace for the gnu compiler |
March 8, 2017, 09:00 |
Uwe Pilz
Rep Power: 15 |
May it be that myrank points to anywhere and you address a unit which doesn't exist?
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
March 8, 2017, 09:23 |
Karan Gupta
Rep Power: 9 |
This is the make file I used for running the open source code for which the above program is a part.
What do I do to debug the code using this makefile. I am new to FORTRAN programming so please help me. # make clean : remove .o .mod .M -files and PROG # make mod : compile modules # make : build coulwave_MPI.out # make db : compile files in $(DEBUG) with -g flag PROG = pCOULWAVE.out MODULES = mainvar_module.f FV_var_module.f OBJS = coulwave_MPI.o var_grp.o \ add_bottom_friction.o add_breaking.o add_breaking_ktrans.o \ add_sponge.o allocate_matrices.o bl_define.o \ boundary_condition.o calc_corrector_error.o \ calc_Courant_number.o calc_mass.o calc_maxs_means.o \ calc_overflow.o calc_vel_DA.o calc_vel_dz.o calc_vel_z.o \ create_depth.o create_file.o create_rand_matrix.o \ create_write_xyth.o decomp2d.o dhdt_calc.o exchange2d.o \ exchange2d_int.o find_dxdydt.o find_max_hxx.o find_max_zeta.o \ find_ts_indices.o find_wavelengths.o global_dims.o \ initial_condition.o init_variables.o internal_source_type2.o \ load_eta_in.o load_inputs.o move_shoreline.o \ set_dispersion_coefs.o set_internal_source_coefs.o \ set_loop_limits.o shift_matrices_back.o solit_cnoidal_ic.o \ spectral_analysis.o store_previous_iter.o \ tridiag.o tridiagp.o user_interface.o write_disp_info.o \ write_inputs.o write_maxs_means.o write_surfaces.o \ write_timeseries.o \ FV_var_grp.o FV_allocate_matrices.o FV_interp_xei.o \ FV_interp_xoi.o FV_interp_yei.o FV_interp_yoi.o FV_ix_iy_eval.o F90OBJS = FV_efg_calc.o FV_efg_calc_1D.o FV_estime.o \ FV_interpolations.o FV_ldu.o FV_limiters.o FV_Riemanns4.o DEBUG_FLAGS = -C -g # mpif90 with gfortran compiler COMPILER=mpif90 F90FLAGS= -O3 -ffixed-line-length-0 -ffree-line-length-0 LFLAGS= -O3 -ffixed-line-length-0 -ffree-line-length-0 MOD_OBJ=$(MODULES:.f=.o) main : $(OBJS) $(F90OBJS) $(COMPILER) -o $(PROG) -p $(LFLAGS) $(OBJS) $(F90OBJS) $(MOD_OBJ) %.o : %.f $(COMPILER) -p -c $(F90FLAGS) $< -o $@ %.o : %.f90 $(COMPILER) -p -c $(F90FLAGS) $< -o $@ clean: rm *.o *.mod *~ $(PROG) db: $(COMPILER) $(DEBUG_FLAGS) -o $(PROG) $(OBJS) $(F90OBJS) $(MOD_OBJ) mod: $(COMPILER) -c $(F90FLAGS) $(MODULES) |
Segmentation fault means that you are reading a section in the memory that does not exist.
I can suggest you different things, since you are using writing instruction, make sure the argument of the function are characters, it seems that you are providing scalars instead. Change tamp_mat(1:endx,1:endy, nn_loc), by tamp_mat(:,:, nn_loc). And see if you can solve the issue. My guess is that you call this instruction at the end of each time step. If you call it at the end of the computation change nn_loc by any integer to see if you can access that part of the memory. Segmentation faults are sometimes hard to spot but the best way is to do that. |
March 8, 2017, 09:43 |
Karan Gupta
Rep Power: 9 |
Thanks for the answer. Segmentation fault has gone by choosing tamp_mat(:,:, nn_loc).
March 8, 2017, 10:00 |
Excellent, then check your nnumerical model, because it means that you introduced an error when you performed divided the domain, for example if you have 21 nodes, it means you have 20 cells or volumes. If you have the information stored at each node then i= 1, imax, but if you have the information stored at the center of each node, then i = 1, imax-1.
The solution of changing Change tamp_mat(1:endx,1:endy, nn_loc), by tamp_mat(:,:, nn_loc) basically reads the whole chunk from the memory, but that procedure will mask any error you have in your algebraic equation. Happy Computations!!! |
March 8, 2017, 12:04 |
Filippo Maria Denaro
Rep Power: 71 |
This error is generally due to the fact that the type of the index used in the matrix is not an integer or if is an integer it violates the bounds of the matrix...
March 8, 2017, 12:07 |
#9 | |
Rep Power: 71 |
Note that you have DEBUG_FLAGS = -C -g but also some otpimization options like -O3. For debugging purpose, you must not use optimization. |
Fortran programming style | Shenren_CN | Main CFD Forum | 6 | February 4, 2011 06:57 |
programming language for CFD, C, C++, FORTRAN,.... | hadian | Main CFD Forum | 15 | September 9, 2008 22:19 |
GUI programming with FORTRAN | ztdep | Main CFD Forum | 1 | August 30, 2007 13:22 |
A problem in FORTRAN programming | Behafarid | Main CFD Forum | 6 | August 16, 2006 12:16 |
Fortran programming and 64 bit machine | Q | Main CFD Forum | 4 | November 7, 2005 05:18 |
