question of Volume of Solid-IBM
Old   April 18, 2017, 18:29
Default question of Volume of Solid-IBM
anonymous
aditya92in is on a distinguished road
Question answered, thanks
aditya92in is offline   Reply With Quote
Old   April 19, 2017, 04:35
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by aditya92in View Post
Hi all,
I am doing a masters thesis project on the Immersed Boundary Method. I plan to use the Volume of Solid IBM. To do this, my first test case is to achieve vortex shedding for a cylinder. I am coding a 2D-test case. I use the Fractional Step method, with AB-2 for momentum and diffusion, while, Central Differencing for spatial gradients. I use the Pressure Projection class of Fractional Step Methods, taken from Chorin. My professor had advised me against, using this. He had told me, to use the Pressure Correction, method as opposed to pressure projection, because, we push the velocity to make it divergence free in Pressure Correction, while we remove the divergent part of the velocity field in Pressure Projection, to make it divergence free. I don't understand this reason, very clearly. My understanding is that both do the same thing. Could somebody explain this ?
Thank you
Aditya
The NS system for incompressible flow requires that you get a final solution satisfying the constraint div v =0, no matter of the method you use. The differences between the two methods you cited are more in the nature of the numerical formulation. In particula, in the projection methods the velocity is projected onto the subspace of divergent-free functions so I do not understand the statement "while we remove the divergent part of the velocity field "
FMDenaro is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
multiphaseEulerFoam high Courant number Frenk_T OpenFOAM 5 November 24, 2016 03:23
What is solid volume fraction correction equation Haiqin Main CFD Forum 1 June 22, 2016 01:22
multiphase turbulance case floating error harsha_kulkarni OpenFOAM Running, Solving & CFD 3 February 18, 2016 05:06
Estimation of "inlet solid volume fraction"...? Genanry FLUENT 1 February 15, 2007 10:29
