illogical result !!
Like Tree5Likes
Old   June 6, 2017, 13:14
Angry illogical result !!
dilaw meda
medaouarwalid is on a distinguished road
hello every one, this is a nozzle called ''lobed nozzle'', it has a circular shape at the inlet and a corrugated shape at the exit, in my case, the area of the inlet is 314 mm² . the area of the exit is 213 mm² .
experimentally, the velocity at the center of the inlet area was 7.5 m/s and when i mesured the velocity at the center of the exit it was 4.5 !!!
numérically it was an other thing , when i set inlet velocity at 7.5 it gave me 10 m/s at the exit which i think is a logical result if we consider the continuity equation. now i don't know what to believe because i repeated the experimental many times and i get the same result each time. There is something wrong here but i didnt find it
noting that i used the ''SST K-omega'' model and i set the the walls of the nozzle as '' no slip WALL'' in BC
medaouarwalid is offline   Reply With Quote
Old   June 7, 2017, 08:13
Blanco
Blanco is on a distinguished road
What about the density? Are you injecting a gas?
Blanco is offline   Reply With Quote
Old   June 7, 2017, 08:19
dilaw meda
Hot Air from hair dryer connected to the nozzle inlet
Old   June 7, 2017, 08:26
Blanco
Ok, so density can change between inlet section and outlet section, and all we know is that mflux=dens*A*vel=const. Therefore it is possible that experimental velocity is correct (!). Talking about your simulation: have you double checked the gas properties you're using in the model? Are you using ideal gas or what? Are the wall boundaries adiabatic, fixed T, etc.? What is the distance between inlet and outlet of the nozzle?
Old   June 7, 2017, 08:42
dilaw meda
I didnt check gas properties, i am assuming that the fluid is incompressible because the velocity is not that high to concidere change in density , also for the walls i used the default setting , the distance between inlet and outlet is 90 mm
Old   June 7, 2017, 09:13
Blanco
Ok, so now you have a list of things to check at least.
I don't know which program you're using, so I suppose that your "default" settings for wall are consistent with adiabatic walls.
Another question: is the nozzle "representative" of a small hair dryer in your intentions? If yes, then the "inlet" section is filled with cold air while hot air flows through the outlet section, or I am missing something?
Old   June 7, 2017, 09:42
dilaw meda
First, the program i am using is ansys fluent and i cheked only option ''no slip" in wall BC.
second i am studying the effect of the geometrie of that nozzle on the augmentation of mixing the blowing air with the ambiant air, so the hair dryer is tool to give me hot hair , the outlet of the blow dryer is equal to the inlet of the nozzle. Also, i want to say that i mesure the inlet velocity afther that i joined the nozzle inlet to the blow dryer exit .
Old   June 7, 2017, 09:59
Question
dilaw meda
I went back to the lab and i did other mesurements. This time i mesured the central velocity not only in the inlet and outlet of the nozzle but also in different points of the centerline of the nozzle , here the new results:
- the velocity was 7.5 m/s only in the point of the grid of the exit of the blower ( see image 3 blower +nozzle ) ,
- when i go down a little bit from there , the velocity decreases until 3.15 and stay like this in the cylindre shape of the nozzle until it reaches the corrugated shape of the nozzle
- then it begins to increase until it reaches 4.6 m/s at the exit of the nozzle !!! Any explications please
Old   June 8, 2017, 04:22
Blanco
Now it makes sense to me:
1- the velocity you measured at the center of the nozzle inlet section is not representative of average inlet flow, because it is influenced by the grid and other stuff you have in the blower near its outlet section. I really think the velocity distribution is all but uniform in the nozzle inlet section.
2- going down along the centerline of the nozzle, the disuniformities you have tends to fade out and a more uniform flow is achieved, therefore the 3.15 m/s you mesured on the centerline "could" be considered representative of the mean flow though a nozzle section
3- the velocity you measured on the outlet section of the nozzle is 4.6 m/s in the centerline, I suppose. Here again I don't expect a very uniform velocity distribution on the outlet section, because of the particular geometry, but the continuity equation tells us that we're very close to theory:
3.15 * 314 / 213 = 4.64 m/s
and you have measured 4.6 m/s... It makes sense.
Btw: how are you measuring the local velocity? You have also to consider the influence you have on the flowfield.
FMDenaro likes this.
Old   June 8, 2017, 07:11
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
The setting of the numerical parameters at the inlet is very important... doing RANS you should prescribe a statistically averaged velocity profile. Consider also the requirement of the turbulence model varaibles at the inlet.
What is the geometry before of the inlet of the nozzle?
FMDenaro is offline   Reply With Quote
Old   June 8, 2017, 11:56
dilaw meda
The géométrie before the inlet of the nozzle is in the figure number 1 of the photo in the comments. A conical géométrie with a grid at exit
Old   June 8, 2017, 11:59
dilaw meda
Ok, so i will take the velocity inlet as 3.15 m/s, also To mesure velocity i am using The TSI VELOCICALC® Multi-Function Ventilation Meter 9565-
Thank you for helping me ,m. Cordially
Old   June 8, 2017, 12:03
Well, maybe you could do a try in adding this cone in the simulation.. I don't know how the grid can influence the inflow in the nozzle, in general a grid is used to make the flow more homogeneous...
If you use the incompressible formulation you can prescribe either the velocity or the pressure, what measurement about the pressure do you have?
Old   June 8, 2017, 12:07
dilaw meda
I didnt mesure the pressure because i am doing a dynamic study and i am interessting just in velocity, should i do mesurements of the pressure also ?
Old   June 8, 2017, 12:14
The key is that if you use RANS, you should measure a statistically averaged profile at the inlet (at least a sufficient number of points)... Are you able to do such a measure on the plane at the inlet?
Old   June 8, 2017, 12:21
dilaw meda
Well the mesurements tool (
The TSI VELOCICALC® Multi-Function Ventilation Meter 9565-) has a probe wich dont allow me to do much mesurements at that plane ( i think you mean the grid) , maybe at the center and near to the nozzle walls thats all
Old   June 8, 2017, 12:23
would be more simple to do the measure in the cone plane before the nozzle??
Old   June 8, 2017, 12:25
dilaw meda
the cone is a small blow dryer i cant take off the grid of the exit
Old   June 8, 2017, 12:46
you can try to add the full cone in the simulation and prescribe a turbulent profile at the inlet of the cone...
Old   June 8, 2017, 12:48
dilaw meda
I dident understand what do you mean by prescribe a turbulent profile at the inlet of the cone , can you please explain more.
Issues when simulating nozzle flow with outside region blais.bruno SU2 4 March 13, 2024 14:04
Convergent-Divergent Nozzle with MATLAB Obad Main CFD Forum 8 June 2, 2020 14:10
Supersonic Nozzle Exhaust Simulation mikeh FLUENT 0 May 1, 2014 21:28
Flow simulation in a Pelton turbine nozzle fivos FLUENT 0 April 19, 2011 11:46
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 01:45
